Old 13-12-2007, 10:54 PM   #1 (permalink)
clmlbx's Avatar
Default how does increment & for loops work in c?
a=2
printf(++a * a++ * a++ * ++a)
answer is 216
how ??
and how is for loop used ?
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 13-12-2007, 11:02 PM   #2 (permalink)
Burning Bright
anantkhaitan's Avatar
Default Re: how does increment & for loops work in c?
bcoz we start count from right side.. now look
++a -> 3
a++ -> 4
a++ -> 5
++a -> 6
and ultimately 6*6*6*6 gives 216
as per the syntax is
for(initialization;condition;value modification){loop body}
Example:
for(int i=0;i<10;i++)cprintf("%d",i);
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 13-12-2007, 11:23 PM   #3 (permalink)
clmlbx's Avatar
what about this
printf(++a*a++*++a)
ans 45
^^^ you mean to say left to right
why did u took
6*6*6*6
what is the difference between pre & post increment
Old 14-12-2007, 12:24 AM   #4 (permalink)
Boom Bhadam Dhishkyao
timemachine's Avatar
Pre increment : Increment then operate
Post increment : Operate then increment
In my life, there are only two rules....
Rule No 1: I am always right...
Rule No 2: If i am wrong, please see rule no 1 again
timemachine is offline
Old 14-12-2007, 12:58 AM   #5 (permalink)
The Lord of Death
Yamaraj's Avatar
Guess you people skipped sequence points and their importance while reading your books. And BTW, that code is non-standard.
Yamaraj is offline
Old 14-12-2007, 12:56 PM   #6 (permalink)
Burning Bright
@clmlbx
You are correct brother..What I told you was my CBSE based bookish knowledge.. I am sorry for that..
It should have been : 4*3*3*3 thats what logic says ..Well today I tried the program (GCC) and output was 108 equals to 4*3*3*3
#include<stdio.h>
int main()
int a=2;
printf("%d",++a*a++*a++*++a);
For your second problem the answer should be 36 i.e. 4*3*3 and that is what I got after compiling
Maah! Blog
Old 14-12-2007, 01:44 PM   #7 (permalink)
Google Bot
Pathik's Avatar
Originally Posted by clmlbx
a=2
answer is 216
how ??
See
++a means a is first incremented then used and a++ means a is first used then incremented.
So this would mean (3*3*4*6) = 216
what about this
printf(++a*a++*++a)
ans 45
why did u took
6*6*6*6
And this would mean (3*3*5) = 45..
Though the ansewrs may vary with the compiler used.
Pathik is offline
Old 14-12-2007, 03:27 PM   #8 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^exactly guys listen up!!different compiler interprets these increments inside printf statements differently afaik,so its like try before you use kind of thing.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 15-12-2007, 12:12 AM   #9 (permalink)
clmlbx's Avatar
can it be more clear ?
add one before or after it is the same thing ..............
how will this program work?
1
12
123
1234
12345
I know using "for" loops and using "\t,\n" but how ............
1
2 4
3 6 9
4 8 12
5 10 15 20
Old 15-12-2007, 01:04 AM   #10 (permalink)
Pawned!... Beyond GODLIKE
fun2sh's Avatar
its simple. wen priority is same then unirary exp are evaluated from right to left.
so here is wat happens for
1. a++ -----> means the current value of 'a' is used in exp then it is incremented
2. ++a------> means the current value is incremented by 1 first then that new incremented value is used in the code.
so for ur exp
++a..................*...............a++.......... ......... *........a++ ....................* ++a
3 (first incre ..................3 (use then ............. 4(use curren ......................6(coz last a=5)
then use,a=3 now)..........incre,a=4 now)..........then incre,a=5now
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach :mrgreen:!!!!!!!!
fun2sh is offline
Old 15-12-2007, 10:17 AM   #11 (permalink)
clmlbx's Avatar
guys I know this is not correct but can someone write that programme for me ..
these are like examples, I have many of them ,so if I got to know how u did this then I will try others
post no. 9
Old 15-12-2007, 10:51 AM   #12 (permalink)
Commander in Chief
QwertyManiac's Avatar
Here you go. 3 simple loop constructs. The i-loop is used for the number of lines to print, and the j-loop is used to display the content needed.
#include<stdio.h>
int main(void)
	int i,j;
	for(i=1;i<6;i++)
		for(j=1;j<i+1;j++)
			printf("%d ",j);
		printf("\n");
	printf("\n");
	for(i=1;i<6;i++)
		for(j=1;j<i+1;j++)
			printf("* ");
		printf("\n");
	printf("\n");
	for(i=1;i<6;i++)
		for(j=1;j<i+1;j++)
			printf("%d ",i*j);
		printf("\n");
	printf("\n");
	return 0;
Outputs as:
1
1 2
1 2 3
1 2 3 4
1 2 3 4 5
1
2 4
3 6 9
4 8 12 16
5 10 15 20 25
Harsh J
www.harshj.com
QwertyManiac is offline
Old 15-12-2007, 09:44 PM   #13 (permalink)
Google Bot
Pathik's Avatar
#include<stdio.h>
int main(void)
int i,j;
for(i=1;i<6;i++)
for(j=1;j<i+1;j++)
printf("*");
printf("\n");
printf("\n");
return 0;
Arey just remove the SPACE after the * in the printf.
Pathik is offline
Old 15-12-2007, 09:52 PM   #14 (permalink)
clmlbx's Avatar
hi
this all are from left
how can I give output from right ?
means output to right side of screen
Old 15-12-2007, 09:53 PM   #15 (permalink)
Google Bot
Pathik's Avatar
Do u need output starting from the right side of the screen or aligned to the right??
Pathik is offline
Old 15-12-2007, 10:02 PM   #16 (permalink)
clmlbx's Avatar
STARTING FROM THE RIGHT SIDE AND ALSO ALIGNED TO RIGHT
AGAIN CAPS.......
Old 15-12-2007, 11:21 PM   #17 (permalink)
AGAIN CAPS.......
Use ur intuition to solve this
I know u can do it, ,and stop forgetting,probably u will suffer from Alzhemeir later. Make ur barin sharp
Faun is online now
Old 16-12-2007, 11:12 AM   #18 (permalink)
aditya_v's Avatar
guys, what solutions u are giving is wrt TC only
C++ doesn't enforce this issue, as said by Bjarne Stroustrup
What's the value of i++ + i++?
It's undefined. Basically, in C and C++, if you read a variable twice in an expression where you also write it, the result is undefined. Don't do that. Another example is:
v[i] = i++;
Related example:
f(v[i],i++);
Here, the result is undefined because the order of evaluation of function arguments are undefined.
Having the order of evaluation undefined is claimed to yield better performing code. Compilers could warn about such examples, which are typically subtle bugs (or potential subtle bugs). I'm disappointed that after decades, most compilers still don't warn, leaving that job to specialized, separate, and underused tools.
aditya_v is offline
Old 16-12-2007, 11:31 AM   #19 (permalink)
Commander in Chief
hi
Look for Output flags (printf flags) in your text book. Do the guys at Ape-tech not teach you ANYTHING at all? These questions are very trivial even for a new programmer!
Harsh J
www.harshj.com
Old 16-12-2007, 02:16 PM   #20 (permalink)
clmlbx's Avatar
Smile Re: how does increment & for loops work in c?
I missed one class and then to I want to complete this assignment to make a good impression .( my prevoious was not good )
nothing more, and here guys are to help so I asked.....
Old 16-12-2007, 02:25 PM   #21 (permalink)
put ur brain into the subject, logic is all u need.
These things are the simplest ones, the real nightmare is advanced data structures. So save ur questions for that time.
U posted now without CAPS on
Faun is online now
Old 16-12-2007, 02:59 PM   #22 (permalink)
Commander in Chief
All you have to do is search.
What you are asking for is left justification I think, so read up on the printf function at CPlusPlus, read the flags part:
http://www.cplusplus.com/reference/c...io/printf.html
Harsh J
www.harshj.com
Old 16-12-2007, 05:12 PM   #23 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I think the only reason this thread has these many replies is because this being a simple question, everyone can "prove" that he/she is a programmer
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 17-12-2007, 09:55 PM   #24 (permalink)
clmlbx's Avatar
ok guys whatever you say ?
I did not try and tomorrow morning is my class so can anybody give e the code ?
please......please
and
"-" = spaces
please some one give me code
Old 17-12-2007, 10:14 PM   #25 (permalink)
Commander in Chief
Don't ask code again, its time you set into dusted off your brain-cobwebs and put it to some use!
#include<stdio.h>
int main(void)
    int i,j;
    char a='*';
    for(i=6;i>0;i--)
        for(j=6;j>i;j--)
            printf("  ");
        for(j=1;j<i;j++)
            printf("%c ",a);
        printf("\n");
    printf("\n");
    for(i=1;i<6;i++)
        for(j=5;j>i;j--)
            printf("  ");
        for(j=1;j<i+1;j++)
            printf("%c ",a);
        printf("\n");
    printf("\n");
    return 0;
Outputs as:
As you expect.
Harsh J
www.harshj.com
Old 17-12-2007, 11:10 PM   #26 (permalink)
clmlbx's Avatar
thank you very much
thanxx a lotttttttt
Work, Work & Work.... u get no raise ! vish786 Chit-Chat 5 14-09-2007 03:49 PM
Will it work? Cool G5 Mobiles and Tablets 5 24-12-2006 02:24 PM
fruity loops tutorials pranavrahul QnA (read only) 7 01-11-2006 11:24 PM
Fruity Loops Studio 5 rajkumar_personal QnA (read only) 7 08-06-2005 06:35 PM
FRoooTY loops Help vijaythefool QnA (read only) 4 09-01-2005 09:42 PM
