Old 20-08-2007, 10:07 PM   #1 (permalink)
william's Avatar
Default Qt where r u?
guys
can anyone tell me from where can i download Qt software. i want to do gui programming with that but can' find the software. i visted their site but its really confusing and also it reuires some registration and u need to purchase that. isn't there any free version and if it is then can u pls provide link to download it.
thanks in advance
The secret of creativity is knowing how to hide your sources.
Albert Einstein
william is offline
Old 20-08-2007, 10:56 PM   #2 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Default Re: Qt where r u?
http://trolltech.com/developer/downloads/qt/windows
Download the Windows Version From any of the Mirrors Here .
Or download this if you want a Direct Link:
http://ftp.iasi.roedu.net/mirrors/ft....3.1-mingw.exe
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 21-08-2007, 03:40 PM   #3 (permalink)
william's Avatar
well thanks friend but i have alreday downloaded zip version from this site its size is 46 MB is the second link u have provide and zip version are same i hope so.
Albert Einstein
william is offline
Old 21-08-2007, 08:04 PM   #4 (permalink)
unni's Avatar
Don't forget to download MinGW and if possible Cygwin (for gdb etc.). Happy cuting.
unni is offline
Old 21-08-2007, 08:13 PM   #5 (permalink)
FooBar Guy
GNUrag's Avatar
william, Qt is freely available from trolltech site under GPL licence if you are going to make Free/Open Source software or learning the Qt apis. Qt is dual licensed, so if you are planning to write commercial/proprietary applications then you need to buy the enterprise editions.
http://www.MovieAB.com - A tiny movie mashup!
GNUrag is offline
Old 21-08-2007, 08:18 PM   #6 (permalink)
C# Be Sharp !
i think what you need is a tutorial on how to use Qt .
http://doc.trolltech.com/4.0/tutorial-t1.html
Check the documentation provided with the Zip you downloaded that'll help ya get started .
Old 21-08-2007, 08:46 PM   #7 (permalink)
Google Bot
Pathik's Avatar
@zeeshan have u made anything using QT API??
Pathik is offline
Old 21-08-2007, 09:55 PM   #8 (permalink)
william's Avatar
i have doenloaded bot Qt and Mingw and now i want to know with qt how to use c++ to craete apps. coz when i open the designer window then are various tols which u can simply drag and drop, what i want to know is that how will u use c++ to your apps to add objects or do something.
Albert Einstein
william is offline
