Old 08-08-2007, 07:49 PM   #1 (permalink)
Default C++:Adding two numbers
We have just started C++ in college
#include <iostream>
using namespace std;
main()
{ int a,b,c;
  cout<<"Enter two nos.:";
  cin>> a >> b;
  c=a+b;
  cin.get();
  cout<<"Sum is"<<c<<"";
  cin.get();
but on compiling and running it{no errors here}nothing happens when i enter two nos. and press enter.Why is it so??can someone guide me??
spinach-guy is offline
Old 08-08-2007, 08:24 PM   #2 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Default Re: C++:Adding two numbers
^^^Me too .
Help me
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 08-08-2007, 08:40 PM   #3 (permalink)
The Frozen Nova
casanova's Avatar
May I know which compiler are you using.
This program will run properly
#include<iostream.h>
main ()
int a,b,c;
cout<<"Enter two nos:: " ;
cin>>a>>b;
c=a+b;
cout<<"Sum is :: "<<c ;
www.nerdweed.blogspot.com
casanova is offline
Old 08-08-2007, 10:16 PM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
Is there any need to use instances of cin.get() ?
See in the Output window of the compiler. u might see the result/ o/p their.
Try using getch(); function instead at the end.
Try using getch(); function in the end instead.
http://twitter.com/blueshift155
blueshift is offline
Old 08-08-2007, 11:16 PM   #5 (permalink)
#include <iostream>
main()
{ int a,b,c;
  cin>> a >> b;
  c=a+b;
  cin.get();
  cin.get();
No need to use cin.get(). That too for 2 times!!!
When supplying input add a space between the numbers.
Even current program runs fine in MSVC6.
Which compiler you are using?
Also if using Tubro C++ 3 or similar DOS based compiler, then remember they are really old. Instead try using free Microsoft VC++ Express Edition which is based on current standard.
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 08-08-2007, 11:51 PM   #6 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Dev C++?
Old 08-08-2007, 11:52 PM   #7 (permalink)
NP : Crysis
xbonez's Avatar
leave out all the complications. just run
#include<conio.h>
clrscr();
int a,b;
cin>>a>>b;
cout<<a+b;
getch();
simple as tht
xbonez is offline
Old 09-08-2007, 09:29 AM   #8 (permalink)
whoopy_whale's Avatar
Don.t forget to add the main() function too...
#include<conio.h>
void main()
clrscr();
int a,b;
cin>>a>>b;
cout<<a+b;
getch();
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 09-08-2007, 10:21 AM   #9 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
And what's with your second line: using namespace std;
It also of no use.
navjotjsingh is offline
Old 09-08-2007, 10:40 AM   #10 (permalink)
piyush gupta's Avatar
^^thats staandard namespace u use for ur program not useful here but itzz very useful in big projects with 1000s of code
piyush gupta is offline
Old 09-08-2007, 01:22 PM   #11 (permalink)
I am using bloodshed Cev C++ which i got from a Digit CD
It also of no use.
Without using this,i get error like cin,cout not defined...something like that
What's the exact use of this function.has it got something to do with user needing to press enter to continue??also what's the use of cin.ignore()??
Old 09-08-2007, 05:50 PM   #12 (permalink)
g_goyal2000's Avatar
Why not simply use Turbo C++???
It's much better & easy to use for starters.
Here's the link to Turbo C++
http://rapidshare.com/files/47910015/TURBOC.EXE
Download it, open the file using Winzip or Winrar and extract it to C: drive.
Be sure to check that the option to use path names is checked otherwise the files will overwrite themselves & u'll have a corrupt complier in your hands.
Do Not execute the file directly by double clicking on it.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 09-08-2007, 06:10 PM   #13 (permalink)
The Frozen Nova
casanova's Avatar
Dint want to start a new thread as problem with the compiler in question.
When I run a Hello world program in C using Dev-CPP, I get the following error.
Compiler: Default compiler
Executing gcc.exe...
gcc.exe "C:\Users\Casanova\Documents\HelloWorld.c" -o "C:\Users\Casanova\Documents\HelloWorld.exe" -I"F:\Apps\Dev-Cpp\include" -L"F:\Apps\Dev-Cpp\lib"
gcc.exe: installation problem, cannot exec `cc1': No such file or directory
Execution terminated
Compilation successful
What to do?
casanova is offline
Old 09-08-2007, 10:41 PM   #14 (permalink)
First of all it is good that you are using Dev C++ which is a good C++ compiler.
It is needed. Read more about namespace. It is a new concept introduced in ISO C++. It is needed in most of the new version compilers.
This is not needed. It was a function used to get a single character from input stream. It is just a way to get character from keyboard like getch() or getche() used in C. For your program it is not needed at all. Read more about 'cin' from whichever book you are using. I would suggest Balaguruswamy as a good book to beginners. There are others also but this does provide a better explaination about all the things related to STL for the beginners.
sandeepk is offline
Old 10-08-2007, 04:08 PM   #15 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Arrow Re: C++:Adding two numbers
Hey
I hv also just started C++........May be thsi will help u......
#include<conio.h>
void main()
{clrscr();
int a,b;
cin>>a>>b;
cout<<a+b;
getch();
or
#include<conio.h>
void main()
{clrscr();
int a,b;
cout<<"input 1st no";
cin>>a;
cout<<"input 2nd no";
cin>>b;
cout<<a+b;
getch();
||uLtiMaTE WinNER||
Ron is offline
Old 10-08-2007, 04:13 PM   #16 (permalink)
God of Mistakes...
Garbage's Avatar
Let me post a good ANSI C++ Program ...
# include <iostream>
int main()
    int a,b,c;
    cout << "Enter two numbers : ";
     cin >> a >> b;
    c = a + b;
    cout << "Addition = " << c << endl ;
    system ("PAUSE");
    return 0;
This is compiling perfectly on Dev C++
@ Ron
Let me tell u bro, the newer versions, there is no need to use ".h" in names of header files. If u use them, they are considered as backward headers.
But, if u r using OLD TC3 compiler, then it should be there.
Also using namespaces std; will NOT work in that compiler.
Better to go for new standards. U my try Dev C++
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 10-08-2007, 04:55 PM   #17 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Thnks Bro......i was not knowing this..as I hv also just started C++...probably 7 Days........
Do u hv some basic tutorial.....as I am unable to get the tutorail...........Our School teacher is mad.....She is teaching us carelessly.without giving any notes............It is out of our Ncert course book...........I am studing in class 10......
.. .......Can i get the link of Dev C++................
||uLtiMaTE WinNER||
Ron is offline
Old 10-08-2007, 07:35 PM   #18 (permalink)
The Lord of Death
Yamaraj's Avatar
    system ("PAUSE");
[snipped...]
Sorry, but this one statement makes your program a nonstandard one.
Read more about it - http://www.gidnetwork.com/b-61.html
Yamaraj is offline
Old 10-08-2007, 08:11 PM   #19 (permalink)
God of Mistakes...
Garbage's Avatar
Smile Re: C++:Adding two numbers
@Ron ,
From HERE u can download Dev C++
Let me answer some of the things...
I've never understood why system("PAUSE") is so popular.
Bcoz it is handy !!!
This pause is very useful when your IDE won't wait as you test a program and as soon as the program finished the window closes taking all your data with it.
Thats why I used it !!!
t's not portable. This works only on systems that have the PAUSE command at the system level, like DOS or Windows. But not Linux and most others..
Let me tell you, C/C++ programs are NEVER portable. So why to bother for a single statement ???
You must include a header you probably don't need: stdlib.h or cstdlib
I think, he must be talking for C, NOT for C++. Bcoz I haven't included those headers.
Hope this is clear now !!!
Garbage is offline
Old 10-08-2007, 08:17 PM   #20 (permalink)
Commander in Chief
QwertyManiac's Avatar
C/C++ sources are portable if you write it for portability (w/o OS sensitive stuff). Programs aren't, right.
Why bother with IDEs and all when you've just started learning. Get a good Linux distro and G++/CC your way through the code.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-08-2007, 09:49 PM   #21 (permalink)
damn busy...
utsav's Avatar
i am using turbo c++ ver 3.0 from the last 18 months . I am in 12th now and the computer teacher is very impressed from my programming skills.though i don't know programming very deeply but according to ISC board standards it is sufficient.
can any1 tell me from where to download the latest version.I am low on bandwidth that's why i am not downloading the rapidshare link given bu goyal2000. i want 2 download the latest version
MSI GX660 with ATI 5870 ultimate gaming lappy
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 10-08-2007, 10:07 PM   #22 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
No man , coz Turbo C++ is NOT standard C++ . It does not support the ISO C++ Specification and thus is usless in the current context , using any FRee IDE(Visual C++ Express , or borland's free compiler) will be much better.
also , Turbo C++ does NOT run fine under Windows XP(which is what the majority uses)
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 10-08-2007, 11:11 PM   #23 (permalink)
The Frozen Nova
casanova's Avatar
Thx Zeeshan for nice info. Can someone sort out the problem I mentioned in Post #13
casanova is offline
Old 11-08-2007, 11:46 AM   #24 (permalink)
damn busy...
utsav's Avatar
Unhappy Re: C++:Adding two numbers
turbo c++ consumes 100 % cpu on my p4 3 GHz system .unbelievable
www.techjunkiez.com
utsav is offline
Old 11-08-2007, 04:05 PM   #25 (permalink)
Commander in Chief
I think all 16-bit apps do that?
@casanova - Try reinstalling GCC packages? Looks like an incomplete or limited installation which is thus reporting cc1.exe is missing..
Harsh J
www.harshj.com
Last edited by QwertyManiac; 11-08-2007 at 04:05 PM. Reason: Automerged Doublepost
Old 11-08-2007, 04:36 PM   #26 (permalink)
I am Optimus Prime
Turbo C++ does run under XP. I run it successfully.
Old 12-08-2007, 03:30 PM   #27 (permalink)
I too have problems running Turbo C++ on my Win XP machine. My sister uses it for her 12th class programs. I don't need it, but whenever she tries to make it fullscreen then the whole computers just freezes. (Using Alt+Enter). What you need to do to work it properly?
sandeepk is offline
Old 12-08-2007, 03:41 PM   #28 (permalink)
Google Bot
Pathik's Avatar
Use dev c++..
Pathik is offline
Old 12-08-2007, 05:15 PM   #29 (permalink)
I am Optimus Prime
Don't run TC using its shortcut. Directly go to bin directory and click on TC.exe I just tested my copy of Turbo C++ and it still works nicely on XP SP2.
Old 12-08-2007, 06:50 PM   #30 (permalink)
The Frozen Nova
casanova's Avatar
@sandeepk
Don't start TC from windows. Go to command prompt, then navigate to tc and then start it from there. U won't have any problem
@qwerty
I had made a full install. Is it coz I am using Vista?
casanova is offline
serial numbers of win xp sp2 pravesh_4766 Software Q&A 3 30-04-2006 08:32 PM
Usb pin numbers beyondthegracefgod Peripherals 5 07-11-2004 02:51 PM
