Old 12-08-2007, 10:51 PM   #31 (permalink)
Default Re: C++:Adding two numbers
@navjotjsingh & casanova
Thanks!!! It is working. Why does this happen with shortcut?
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 13-08-2007, 12:56 PM   #32 (permalink)
The Frozen Nova
casanova's Avatar
TC is a 16 bit proggy. When you run it from command, it is being handled more efficiently.
www.nerdweed.blogspot.com
casanova is offline
Old 13-08-2007, 08:48 PM   #33 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
But still then it consumes 100% on my PC .
and anyways , Turbo C++ Does Not support Standard C++ , so it's useless anyways .
Why not use Visual C++ Express or GCC when they're much better ?
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 13-08-2007, 08:56 PM   #34 (permalink)
Yes I do use VC++ only. But my sister needs TC as in college they told you to use TC only. Also for exams it is the one that is available. When will these colleges learn that TC is really old to be any useful these days?
sandeepk is offline
Old 13-08-2007, 09:11 PM   #35 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Blame it on Old CBSE Course Too. They still teach old format C++.
navjotjsingh is offline
Old 13-08-2007, 11:02 PM   #36 (permalink)
The Frozen Nova
casanova's Avatar
Yes, academics spoil things. They ask to use TC which is lacking in features.
@zeeshan
Yes, it still uses lot of cpu. But it works atleast
casanova is offline
Old 14-08-2007, 11:14 AM   #37 (permalink)
C# Be Sharp !
Well actually there's an alternative to TC that will compile the old format code just fine under windows XP and into a 32 bit executable .
Here's how u can use Borland's FREE C++ Compiler along with the Relo IDE[i use it myself for school program testing ] :
1. Get Borland's Free C++ Compiler Here
http://dn.codegear.com/article/20633
2. Download the Free Relo IDE Here
http://www.fifsoft.com/relo/
3. Now Install Borland's Compiler First n then Relo IDE , it will ask u for Compiler Path during setup n just provide the path where u installed Borland Compiler n that's it, u have yor Development Enivronment Set-up and ready to go
Old 14-08-2007, 04:32 PM   #38 (permalink)
Thanks for this advice. It is better than TC!!!
sandeepk is offline
Old 14-08-2007, 06:26 PM   #39 (permalink)
God of Mistakes...
Garbage's Avatar
@ sandeepk,
have u ever tested DevC++ ??? It is far better than this! Bcoz it supports OLD as well as NEW (ISO) C++
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 14-08-2007, 08:02 PM   #40 (permalink)
C# Be Sharp !
Originally Posted by shirish_nagar
@ sandeepk,
But problem is tat it DOES NOT Support borland specific headers[ conio.h anyone ? ] which are taught in the ICSE n CBSE curriculum
Old 14-08-2007, 08:08 PM   #41 (permalink)
C# Be Sharp !
Originally Posted by Kenshin
Use dosbox i used to use dosbox to run TC,...it runs fine under dosbox....but i hate tc hehe.....now we r usin assembler and its turbo assembler and it looks same like tat TC... i hate everythin tat looks like tc...hehe
Biggest prob is that TC does not run fine under my PC in ANY way , that's y use Relo
Old 14-08-2007, 08:45 PM   #42 (permalink)
God of Mistakes...
Garbage's Avatar
Smile Re: C++:Adding two numbers
Who says that ???
Infact take a look @ this code,
# include <iostream.h>
# include <conio.h>
int main()
    int a,b;
    cout << "Enter 2 numbers : ";
     cin >> a >> b;
    cout << "Addition = " << a+b;
    getch();
This code is perfectly valid in Dec C++.
And if u can see, then I've included conio.h & used getch() from that lib.
Garbage is offline
Old 14-08-2007, 08:58 PM   #43 (permalink)
C# Be Sharp !
well , it frankly wasn't valid the last time i used Dev C++(that was when v4 was launched i suppose)
anyways , use whatever u like , except TC that is
Old 14-08-2007, 09:17 PM   #44 (permalink)
The Lord of Death
Yamaraj's Avatar
Who says that ???
# include <conio.h>
int main()
    int a,b;
     cin >> a >> b;
    getch();
It does not conform to the ISO C++ standards, regardless of the fact that even GCC can compile this code. The C++ programming language has nothing to do with screen, keyboard input and other I/O hardware interfacing.
Yamaraj is offline
Old 14-08-2007, 09:20 PM   #45 (permalink)
I see right through you.
Sykora's Avatar
@shirish_nagar : That is definitely not valid code in dev c++. Dev c++ uses mingw compiler, which is based on gcc, and will choke on that code because it conforms to standards written in about 1995, and since then have become outdated. Even if it does work, you must have copied conio from a TC install to your dev include directory.
EDIT : Slightly late...
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 14-08-2007, 09:23 PM   #46 (permalink)
God of Mistakes...
Garbage's Avatar
^^ nah....
I've just installed DevC++ on my machine & compiled this!
Though it gives warnings bcoz I've used "iostream.h" instead of "iostream". But it compiled & run.
Garbage is offline
Old 14-08-2007, 09:51 PM   #47 (permalink)
g_goyal2000's Avatar
Turbo C++ does NOT run fine under Windows XP(which is what the majority uses)
Actually it does. It runs fine on all Windows w/o any service pack(s). I've run it successfully on Win 98, 98SE, 2000, ME, XP, 2003. I've been using it for more than 2 years & still do.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 15-08-2007, 07:01 AM   #48 (permalink)
God of Mistakes...
Garbage's Avatar
^^ yeh, just thing is that u don't have to INSTALL it, copy the TCC ot TC++ folder & navigate thru folder in command prompt.
Then it should work fine!!!
Garbage is offline
Old 15-08-2007, 08:13 PM   #49 (permalink)
C# Be Sharp !
But it takes up 100% CPU time on my machine(n all other Win XP machines i've used)
Old 15-08-2007, 08:31 PM   #50 (permalink)
I am Optimus Prime
Seems problem at your end. Here everything is Ok.
serial numbers of win xp sp2 pravesh_4766 Software Q&A 3 30-04-2006 08:32 PM
Usb pin numbers beyondthegracefgod Peripherals 5 07-11-2004 02:51 PM
