Old 10-05-2007, 06:37 PM   #1 (permalink)
Burning Bright
anantkhaitan's Avatar
Unhappy File handling using GCC/G++
Friends point me where I m wrong.
#include<fstream>
#include<iostream>
int main()
ofstream f;
f.open("1.txt");
f.put(65);
std::cout<<"Inserted";
f.close();
return 1;
Command for compilation :
$ g++ a.cpp -o a
Error message(s):
a.cpp: In function ‘int main()’:
a.cpp:5: error: ‘ofstream’ was not declared in this scope
a.cpp:5: error: expected `;' before ‘f’
a.cpp:6: error: ‘f’ was not declared in this scope
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 10-05-2007, 07:32 PM   #2 (permalink)
sam_1710's Avatar
Default Re: File handling using GCC/G++
u forgot to give namespace buddy!!!
this code will compile..
#include<fstream>
#include<iostream>
using namespace std;
int main()
ofstream f;
f.open("1.txt");
f.put(65);
f.close();
return 1;
sam_1710 is offline
Old 10-05-2007, 07:57 PM   #3 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Yeah.. Absolutely correct... As per the ANSI C++ standards, the headers are not longer considered as files.. They are referred from namespace std.....Hence, inclusion of
is a standard..
Don't forget it.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
Old 10-05-2007, 09:49 PM   #4 (permalink)
I see right through you.
Sykora's Avatar
Once you've used the namespace, the std:: is not necessary.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 10-05-2007, 10:39 PM   #5 (permalink)
Burning Bright
Thanks a million buddies.. I thought it was only for console in/out thats why used std:: before cout.. anyways i successfully compiled my code..
#include<fstream>
#include<iostream>
int main()
ofstream f;
f.open("1.txt");
f.put(65);
cout<<"Inserted";
f.close();
return 1;
Maah! Blog
Old 12-05-2007, 02:34 PM   #6 (permalink)
Burning Bright
Friends I will be really grateful if anyone of u can suggest me alternative to common used conio functions like getch(), gotoxy(), kbhit(), _setcursortype() etc.
Maah! Blog
Old 12-05-2007, 10:17 PM   #7 (permalink)
saurabh.sauron's Avatar
for linux, i dont think is required for getch()...anywayz, here is one.
system("Pause");
i dont think linux is able to recognize it.
saurabh.sauron is offline
Old 12-05-2007, 11:33 PM   #8 (permalink)
webgenius's Avatar
are you programming under linux? if yes, then you can't use <conio.h> under GCC.
webgenius is offline
Old 12-05-2007, 11:37 PM   #9 (permalink)
Debian Rocks!
freebird's Avatar
Linux
Anjuta is a good gui ide for gcc,g++ and more.eclipse also there.
but CLI compiling helps learning gcc core isnt it?
"The day windows users wake up to reality, it will be doomsday for Microsoft."UNIX like OS are more secure.get urself out 4m M$ http://whylinuxisbetter.net http://tinyurl.com/2amjjc http://fsf.org
freebird is offline
Old 13-05-2007, 10:04 AM   #10 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
well mate , conio.h is a propreitary header file of Borland Inc , you won't find it bundled with ny oher compiler than borland compilers , so it's better you use Standard C++ n not rely on compiler-specific until it's a must ..
better still i sugget you Program in C# , it's much easier to program in it than C++ n it has a vast library of functons n you will hardly ever need to use ny external library .
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 13-05-2007, 12:28 PM   #11 (permalink)
1337 |)00|) \m/
C# in Linux ? Is it not proprietary too ? In case it isn't.. I don't think Linux has inherent support for C# , right ?
A side question.... How strong is Python when compared to C++ or C# ?? Give a neutral opinion over it.........
Old 13-05-2007, 01:03 PM   #12 (permalink)
C# Be Sharp !
Python is a scripting language and is not meant for heavy duty System Software development ,
whereas C++/C# are for system level application development .
although C# is a lot easier and as powerful as c++ .
python , Perl , etc r very useful when you wanna do simple tasks n automation like extracting links from web-page , or designing phone-cook kinda software .
also C++/C# give much more performance as they r compiled n Python apps r interpreted .
Old 13-05-2007, 01:04 PM   #13 (permalink)
Burning Bright
Question Re: File handling using GCC/G++
eh! Friends I should have explained why I need getch() and others..Ok my mistake
Here is my explanation, Take this program for example :
int main()
int i=0;
char a[]="Help Me! ",ch;
do
ch=getch();
printf("%c",a[i%9]);
i++;
}while(ch!=27); // 27 means ESC
return 0;
Now in this program whatever key u press.. Only "Help me! " string will be displayed.
Help me in writing the same program without getch().
The same is with kbhit() : This function is used a continuous loop iteration until a key is pressed:
while(!kbhit())
<code>
now I want a similar thing.
Maah! Blog
Old 13-05-2007, 01:35 PM   #14 (permalink)
Sykora's Avatar
I'll try to be as neutral as I can
Python lets you do more, and do it faster. By faster, I don't mean that the program itself is faster, but that it is easier to write a program in python because of the ease of the language.
The drawback is of course, that is slower than compiled languages. This is mainly noticeable in number crunching programs and the like.
The reason why I (and most other Python programmers) prefer python is that the faster program development time is a huge compromise over the performance hit. There are many things you can do in Python that would break your mind in C/C++. Not that it's not possible, just that it's very hard.
Sorry for the off-topic.
-- Sykora --
Sykora is offline
Old 13-05-2007, 01:48 PM   #15 (permalink)
Burning Bright
Friends avoid quarrel between different programming languages here .. plz help me solving my problem.
Maah! Blog
Old 22-05-2007, 02:25 PM   #16 (permalink)
Burning Bright
So this thread is dying, Guys please help me with my problem..
And if anyone can write the same program in Python which I have written in Post no. 13
Maah! Blog
Old 22-05-2007, 04:19 PM   #17 (permalink)
Sykora's Avatar
>>> s = 'Help me! '
>>> i = 0
>>> while True :
...     try :
...             c = raw_input()
...     except KeyboardInterrupt :
...             break
...     print s[i % 9],
...     i += 1
I tested for Ctrl-C rather than Esc.
-- Sykora --
Sykora is offline
uTorrent “announce” URL Handling Buffer Overflow goobimama Technology News 14 16-02-2007 11:06 PM
Handling /dev/dsp in C desertwind Open Source 1 04-01-2007 07:32 PM
Change File size in MB instead of GB in properties of a File rachitar QnA (read only) 4 24-11-2005 09:46 AM
