LinkBack (3) Thread Tools Display Modes
Old 03-02-2007, 08:21 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Red face Output Screen In C++ !
hey frenz.....
can u ppl plz tell me how to take screen shot of output screen in Turbo C++......pressing print screen n then pasting it in paint is of no use ...nothin happens.....
Thanking u ppl in anticipation.....
BlackBerry7100g.
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 03-02-2007, 08:53 PM   #2 (permalink)
Lightbulb Re: Output Screen In C++ !
But when i use it does it.The file i created in one of my tuts was also done by print screen in C++.Does ur printscreen button works fine in otherplaces
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 03-02-2007, 11:30 PM   #3 (permalink)
Default Re: Output Screen In C++ !
on black scring press ALT+Enter
now right click and select mark
select area that u want to copy
and press enter
now open notepad and paste
njoy it
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 03-02-2007, 11:35 PM   #4 (permalink)
SE><IE
Posts: n/a
goto windows > output. Now a ctrl+c would work. No need to select
-seXie
Old 04-02-2007, 11:49 AM   #5 (permalink)
yes siddharth .....printscreen button works fine in otherplaces
Old 05-02-2007, 12:03 PM   #6 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
simple run ur turbo in window mode by pressing alt+enter then u can resize ur turbo and take snapshots using printscreen
u can also use borland c++ which allows u to take snapshots
saurabh kakkar is offline
Old 08-03-2009, 10:04 AM   #7 (permalink)
Hey printscreen command works it worked while copied the output of a C program to MS word. It should work
Bookworm is offline
Old 08-03-2009, 06:10 PM   #8 (permalink)
Freak Beta 1
Dark Core's Avatar
Here's another Solution :
In the full screen view press Print Screen and Paste it in Notepad, It will work
Twitter : www.twitter.com/arunselvakumar :twisted:
Facebook : www.facebook.com/arunselvakumar :evil:
Dark Core is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/programming/48381-output-screen-c.html
how to copy a c program(with output) from Turbo c++ in MS- Word? - Forum - [Look-it] This thread Refback 21-02-2011 11:26 PM
how to copy a c program(with output) from Turbo c++ in MS- Word? - Answers - [Look-it] This thread Refback 13-01-2011 01:28 PM
how to copy a c++ program(with output) from Turbo c++ in MS- Word? - Answers - [Look-it] This thread Refback 04-01-2011 03:25 AM
