Old 14-10-2005, 02:14 PM   #1 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Default Simple programming Error in Java
I copied a simple program from a book. Author is E.Balaguruswami
It was just to show basic input using package io and Datainputstream.
After compilation an error was shown--
Note: filename.java uses or overrides a depricated API
Note:Recompile with-Xlint:deprication for detail
Full code is===
import java.io.*;
class sania
public static void main(String args[])
DataInputStream i=new DataInputStream(System.in);
int c=0;
try
System.out.println("Enter a Number");
c=Integer.parseInt(i.readLine());
catch(Exception e) { }
System.out.print(+c);
nitish_mythology is offline
Old 14-10-2005, 06:30 PM   #2 (permalink)
thats is not an error. Its just a warning meaning that you are using an Outdated API which may not be supported in coming versions. Your compilation was fine. Run the program and it will work.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 15-10-2005, 12:01 AM   #3 (permalink)
aadipa's Avatar
It is just warnning. Which version of Java SDK are you using?
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
