Results 1 to 10 of 10
11-05-2012, 05:05 PM #1Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 1
If there is no sizeof operator in C
I do not have much knowledge about compilers and all.
I have one simple question about C programming.
If there is no sizeof operator in C then does those pointer arithmetic work or not ?
I am very much confused about it.
Please somebody help.
14-05-2012, 09:11 PM #2
Re: If there is no sizeof operator in C
sizeof operator is present in C.
AMD Phenom II X6 1055T|MSI 880GMA-E45|MSI 7770|2x2 Corsair DDR3 1333MHz|CM Elite 310|Corsair CX400W|DELL ST2320L
Myself @ nbaztec.co.in
Build Your Rig! (XBlade) @ nbaztec.co.in - Build Your Rig!
My Inner Artist @ nbaztec.co.in - Designs
14-05-2012, 11:39 PM #3
15-05-2012, 01:57 AM #4
I learned about this operator when learning C, when doing dynamic memory allocation, read up on malloc, calloc.
Project Halcyon V2.1
2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
17-05-2012, 01:38 AM #5
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
25-06-2012, 11:37 PM #6Right Off the Assembly Line
- Join Date
- Jun 2012
- Posts
- 1
yes there is ....if u r having probs using calloc,malloc etc maybe u forgot to use type casting..
26-06-2012, 08:27 PM #7
It will greatly depend on the compiler you have
29-06-2012, 09:07 AM #8
sizeof() is put by the compiler itself when running pointer arithmatic. Without that, pointer arithmatic wont takeplace. That is what I understand as of now.
07-07-2012, 10:35 PM #9poor little me
- Join Date
- Jul 2012
- Location
- internet
- Posts
- 77
hii there i learned this trick back in my college days to find the size of a variable without the use of sizeof() operator .
It works in almost all cases .Although sizeof () is a operator i think in assembly code it comes down to some piece of more basic code .
#define find_size(x) (((char *)(&x+1))-((char *)(&x)))
int main(){
int i;
char c;
double d;
printf("%d\n",find_size(i));
printf("%d\n",find_size(c));
printf("%d",find_size(d));
return 0;
don't ask how to find size() if we don't have # define
That i don't know
08-07-2012, 12:24 PM #10
As cool and hacky as the trick may sound, it's bad code. And not because it does what sizeof() does, but because it is misleading and counter-intuitive. One should take some time out to understand what exactly is happening:
A pointer is nothing but a location to memory, and on a x86 systems it holds a 32-bit address. So effectively it is of type long (4 bytes) = int on x86 architecture.
So without typecasting, the difference between 2 pointers yields the no. of elements or memory locations. But once you typecast the pointer to a long, it is treated as a interger type memory location upon which you can perform the usual arithmetic operations. And what better way to get the number of bytes that to get the difference between 2 consecutive addresses.Code:int i = 1337; printf("i(%d) is located at %d, next location is %d\n", i, &i, &i+1); printf("Number of memory locations: %d - %d = %d\n", &i+1, &i, &i+1 - &i); printf("Number of bytes : %d - %d = %d\n", &i+1, &i, (long)(&i+1) - (long)&i); /** * Output * i(1337) is located at 1834544, next location is 1834548 * Number of memory locations: 1834548 - 1834544 = 1 * Number of bytes : 1834548 - 1834544 = 4 */
So you can ditch that hacky macro, which I'm sure originated from some Indian authored book.AMD Phenom II X6 1055T|MSI 880GMA-E45|MSI 7770|2x2 Corsair DDR3 1333MHz|CM Elite 310|Corsair CX400W|DELL ST2320L
Which network operator in Delhi?
By Micheal in forum Mobiles and TabletsReplies: 10Last Post: 14-04-2012, 06:08 PM -
Mobile Operator ... which is yours ???
By ax3 in forum Mobiles and TabletsReplies: 58Last Post: 13-04-2012, 11:17 PM -
Fwd: What is Operator Overloading!
By mrintech in forum Chit-ChatReplies: 8Last Post: 24-04-2009, 05:08 PM -
Operator logo
By vandit in forum Mobiles and TabletsReplies: 3Last Post: 16-04-2007, 11:29 PM -
Operator Logo Help!
By REY619 in forum Mobiles and TabletsReplies: 13Last Post: 15-12-2006, 01:40 PM
LinkBack URL
About LinkBacks
