Old 26-01-2012, 03:10 AM   #1 (permalink)
XLr8
arpanmukherjee1's Avatar
Default need help with XML and XSD
hi.
i have a xml file with structure
<?xml version="1.0" encoding="UTF-8"?>
<Start Description="nslfjhl">
 <Products Description="sfhsdf">
  <ProductList>
   <Product Mode="02" Key="2" />
   <Product Mode="01" Key="11" />
  </ProductList>
  <CustomKeys>
   <Key Value="4545"/>
  </CustomKeys>
 </Products>
</Start>
now i generated its XSD with xsd.exe in Visual Studio 2010
and generated its class with command
c:\> xsd C:\samlpe.xsd /c /l:CS
now how to update delete and insert into this class.
i do know how to deserialize and serialize with XmlSerializer
any help is welcome. thanks in advance
arpanmukherjee1 is offline   Reply With Quote
Old 26-01-2012, 04:59 PM   #2 (permalink)
I'm a Wannabe Hacker
Prime_Coder's Avatar
Default Re: need help with XML and XSD
Can't say for sure, but maybe this is what you are looking for:
HOW TO: Serialize and Deserialize XML in Visual Basic .NET
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rich Cook
Prime_Coder is offline   Reply With Quote
