Old 20-01-2012, 01:38 AM   #1 (permalink)
Explorer
aroraanant's Avatar
Smile Develpoing a website,need help!!!
Hi guys...
I m new to this section but not so new on TDF and not so good in programming.
I m planning to make a website like gsmarena which will contain specifications and reviews and prices and a lot more info about mobiles,it is my final year project.
I m very good in HTML, CSS, Javascript (including the concept of DOM and validation and also have some knowledge of Sessions and cookies ) and SQL too...yeah I know thats very less as this all is basic...but right now I am also learning ASP.NET and can also work with dreamweaver.And I think I need to have knowledge of PHP and XML which I don't have.And do I need to learn jQuery also??
I m planning to get Linux hosting as I know how to use C Panel very well and C panel has very good features and I can easily add a wordpess blog to my website ,but ASP.NET will not be supported on it.So what you guys need to say about it,do I need to use ASP.NET for making to website or simply tell me what should I do?
I have to complete around 50-70% of the work before March 1st week and rest of the work till May 1st week.
And I was thinking to add a forum instead of a blog,adding a blog is a job of some clicks but I don't know how to add a forum and manage it? Can it be done easily or should I drop the idea of adding a forum and simply add a blog on it.I searched a lil bit on google and there I saw that many scripts are available but how to use them?
There is a friend who will be sharing this job with me(but he has less or the same knowledge that I have)
And I have a lot many questions to ask,but will ask them later on.
So guys tell me from where should I start and what should I do first?
And what are the things(any language or anything) I need to learn?
HTC Incredible S | Nikon S8100 | Dell Inspiron 1525 | Sony VAIO VPCEG25EN | Macbook Pro 13"
aroraanant is offline   Reply With Quote
Old 20-01-2012, 10:12 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Develpoing a website,need help!!!
better go with open source.. u r site will be ready with no extra cost.. and also fully customizable !
if u want both blogging and forum in one site.. then choose for CMS softwares.. famous ones are
Wordpress
Drupal
Joomla
try these 3.. whichever u find easy and useful. use that.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline   Reply With Quote
Old 20-01-2012, 02:48 PM   #3 (permalink)
Resistance is Futile.
coolpcguy's Avatar
won't harm.
what's there to learn in that
not a must.
what should I do?
WordPress + custom theme.
I don't know how to add a forum and manage it? Can it be done easily? Should I drop the idea of adding a forum
Installing a forum is bloody easy, creating a community isn't. Drop the idea, else you're just other place for spambots to throw their crap
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline   Reply With Quote
Old 21-01-2012, 08:05 PM   #4 (permalink)
Explorer
aroraanant's Avatar
Smile Re: Develpoing a website,need help!!!
Wordpress
Drupal
Joomla
For making the blog I will be using wordpress but I need to design the website myself,don't want to use Joomla or Drupal.As its my final year project so have to do the coding myself only.
Anyways thanks for your suggestion
Old 21-01-2012, 08:34 PM   #5 (permalink)
Explorer
aroraanant's Avatar
Originally Posted by coolpcguy View Post
won't harm.
what do you mean by that.As I have to spend sometime in learning.
If I learn it how it will be useful to me?
Please can you tell me.
Ya I know as I already mentioned that I only know few things so just mentioned it as I worked in it 2-3yrs back
not a must.
Ok thanks
I was already gonna do that
Can you tell me how to add a forum if its really easy.
I will be really thankful to you for that.
As I don't care for spambots
Old 21-01-2012, 09:58 PM   #6 (permalink)
coolpcguy's Avatar
jQuery is a js framework, knowing it will help you immensely since you & it'll make your js work a lot easier. PLus there're a lot of plugins for specific tasks, which'll help as you won't have to do the hard work yourself.
First: Which forum do you want to install? Does your host provide fantastico / Softaculous? If so then it's all 1-click install.
You better worry.
Old 21-01-2012, 10:23 PM   #7 (permalink)
Explorer
aroraanant's Avatar
Thanks for that...I will read some tutorials then.
I don't have any idea about it.How about adding a forum just similar to this one(TDF).I haven't got any hosting right now.Have to get it in some time as its my project so will get any,don't want to much money(or can say will see I will get some good hosting for free ).Can you help in that too.As previously I was thinking to buy from godaddy but right now first I m gonna test it on some free hosting then later I will buy something good.
You better worry.
That I will see later.I will manage that.
Old 21-01-2012, 10:30 PM   #8 (permalink)
coolpcguy's Avatar
TDF uses vBulletin which isn't free.
Ask when you're ready to setup
Old 21-01-2012, 11:48 PM   #9 (permalink)
Explorer
aroraanant's Avatar
Tell me some good one which is free
Old 21-01-2012, 11:58 PM   #10 (permalink)
Simple Machines
or
MyBB - Free and Open Source Forum Software
Old 22-01-2012, 12:08 AM   #11 (permalink)
Explorer
aroraanant's Avatar
BTW there are hell lot of people who know a lot about coding and designing a website but don't have any idea of Cpanel.
Originally Posted by ico View Post
Thanks a lot.
I m having a look at the same.
Will get back to you soon
Old 22-01-2012, 12:28 AM   #12 (permalink)
prabhu.wali
prabhu.wali's Avatar
well u are pretty much good to go since u are familiar with html/css/js u need to acquaint urself with php,sql and learn jquery if u've got time on ur hands
Desktop:E7200@2.53GHz|DG41RQ|DDR2 4GB @800MHz|CoolerMaster Storm Enforcer|CM 600W Extreme Power|XFX 9600gt|DELL SP2208WFP|RAZER Goliathus|Creative 2.1 Inspire|HDD Seagate 1TB+320GB
Laptop:Sony Vaio VPCEH26EN
Photography Gear:Nikon D3100 AF-S 18-55mm
Audio Gear:Cowon J3 16Gb|GRADO SR325i Goldies:D|FIIO E7|Sennheiser PX100 & HD202
Our First Venture:www.masminds.com
prabhu.wali is offline   Reply With Quote
Old 22-01-2012, 12:41 AM   #13 (permalink)
Explorer
aroraanant's Avatar
I know SQL also very well.
Ya i know I need to learn PHP and jquery but the thing is that I have not got much time as its my final year and I m hell lot of busy and also we have to spend time friends and family and good sleep is also necessary...LOL
Old 22-01-2012, 11:04 AM   #14 (permalink)
Whompy Whomperson
Nipun's Avatar
phpBB too.
¯_¯_¯_¯_¯_¯_ Yes, I am stupid. ¯_¯_¯_¯_¯_¯_
Need some suggestions/comments:
▒▒ Team Fortress 2 Comic Maker ▒▒
Nipun is online now   Reply With Quote
