You can match strings using strcmp().
Check
strcmp - C++ Reference
So the example there does the exact thing you are looking for...
/* strcmp example */
#include <stdio.h>
#include <string.h>
int main ()
char szKey[] = "apple";
char szInput[80];
do {
printf ("Guess my favourite fruit? ");
gets (szInput);
} while (strcmp (szKey,szInput) != 0);
puts ("Correct answer!");
return 0;
What it does is...
1. Assigning default value to a char array. You can consider char pointer too, in that case you can use malloc() and strcpy(var, value); to set default password.
2. It takes input from the user.
3. And keeps matching until it's matched.
So in your case you can consider taking a variable i and run it for 3 times. In that case go for while loop instead of do...while.
And also you'd need a if...else to print Wrong Answer and Correct Answer depending on matching. And break once it gets matched.
So now try it out yourself and if it doesn't works, post the program here. We'll help you out.
But don't ask us to write your programs, as no one would do so. Not because we can't but because we want you to learn it yourself
Best of Luck.
UPDATE : Don't use gets(), it's dangerous.
Check
Things to Avoid in C/C++ -- gets() , Part 1 - GIDNetwork
So it's better not to practice wrong things.
Thanks to LFC_Fan for correcting me.
