Old 09-01-2012, 01:58 AM   #1 (permalink)
VIP
RazorbladeXtreme's Avatar
Lightbulb A database without using DBMS
I want to store textual encoded data in a file whose internal structure is that of a database's .
The scenario requires saving pages of a diary - one for each day (specific date). I do not want to use 3rd party softwares and want to get it done with programming language alone via file handling (or the apt method).
Could anyone enlighten me how this could be approached (Java) ?
I also need to discuss a bit of cryptography.
I maybe read something about this somewhere and since have assumed that secure systems don't store actual user passwords but use cryptographic hashing algorithm on the password and store the result. When the user re-enters password, the algorithm is applied on the input and the result of this one is matched with the one in database.
The pages I want to encode - I've thought of using DES with user's password being the deciphering key, and username and password's hash in separate plaintext database file. How feasible, secure, and efficient does this sound ?
Please speak of any errors you think in this design.
and, I know this is not as easy as I am thinking
Twitter: twitter.com/SharmaTushar
Facebook: facebook.com/tushar.sharma
RazorbladeXtreme is offline   Reply With Quote
Old 16-01-2012, 02:48 PM   #2 (permalink)
Default Re: A database without using DBMS
Store it in a flat file in a simple 3 part format.
First part will tell how many bytes data you have to read
Second part can hold date
Third part will have your text data.
You can have Monthly/Yearly data files.
enjoy is offline   Reply With Quote
Old 14-03-2012, 02:54 PM   #3 (permalink)
pranav0091's Avatar
Here's one very simple way of doing it.
Write everything onto a plain file, and use a special byte-sequence to mark the end of a post.
As for the cryptography part remember that (if you are building this app just for fun, which is very likely) then bitwise XORing is a ridiculously simple encryption procedure.
Bitwise XOR the data-file once and you get the ciphertext-file, repeat the procedure on the ciphertext and get back your original file. As simple as that.
*edit*
My bad, didnt notice the date...
Anyways will just let the post lie here just in case somebody finds it useful.
HP Pavillion dv4 3016tx | i5 2.33GHz | ATI HD6750M 1GB | 4GB RAM | 500GB HDD
Panasonic HJE120 IEM
N70
pranav0091 is offline   Reply With Quote
Old 14-03-2012, 03:16 PM   #4 (permalink)
XML..................
Faun is online now   Reply With Quote
Old 14-03-2012, 04:14 PM   #5 (permalink)
BIOS Terminator
nims11's Avatar
+1 to XML
easy to manipulate and has huge support in many languages by means of 3rd party libraries
Arch Linux is kind of a bonzai tree, over years u try new things, make small tweaks, and end up with a system that is unique, elegant, and does exactly what u designed it to do.
Hostapd : The Linux Way to create Virtual Wifi Access Point
My Blog
nims11 is online now   Reply With Quote
Old 15-03-2012, 05:13 PM   #6 (permalink)
masterkd's Avatar
for cryptography use md5..google a little bit, you'll find the jar file and 5-6 lines of code required to do that..really simple huh!!
i5 2500K|P8Z68 V PRO|560Ti Hawk|G Skill 8GB 1600MHz|SG 500 GB|WD Passport 1TB|TX850V2|690II Advanced|BenQ G2420HD|Razer Cyclosa Bundle|Razer Goliathus|APC 1.1 KVA|DLink 2730U WiFi Router|Windows 7 X64
Samsung Galaxy Note :hyper:
Steam
masterkd is offline   Reply With Quote
Old 15-03-2012, 11:19 PM   #7 (permalink)
Section Moderator
gopi_vbboy's Avatar
xml...but as database schema gets complex,it gets complex to parse the nodes...xpath is easiest way to parse in such case...you may also use xsl to present data in web...to make it cross platform n independent of os...
gopi_vbboy is online now   Reply With Quote
Old 15-03-2012, 11:32 PM   #8 (permalink)
Mmmph!!!
doomgiver's Avatar
try some nosql.
like mongoDB (its humongous!)
Mmmphh-mphhhh-mmphh mhh!!!
Steam : doomgiver
doomgiver is offline   Reply With Quote
Old 16-03-2012, 05:38 AM   #9 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
If someone wants to avoid the overhead of a DBMS server running all the time, the best way to go about is to use SQLite3. SQLite3 offers an embedded DBMS which is inside a single file and this can be queried and data can be retrieved from this just like an ordinary DBMS and it provides all basic DBMS features.
Check this out: http://stackoverflow.com/questions/4...ava-and-sqlite
Apple iPad 2 16GB WiFi
MetalheadGautham is offline   Reply With Quote
