Old 04-01-2012, 07:27 PM   #1 (permalink)
bijay_ps's Avatar
Default help in starting movie ticket project
Hello friends!! I want to develop a online movie ticket project using either c or c++ language. But I am a bit confused that from where should I start. I mean on which platform. For general coding purpose I have always used either GCC or Turbo C compiler. And I don't knw database connectivity also. So please help me with some suggestions.
Follow 7H3 G33K !nside YOU
bijay_ps is offline   Reply With Quote
Old 05-01-2012, 12:06 PM   #2 (permalink)
Default Re: help in starting movie ticket project
What is your focus here. Getting more hands on experience on C/C++ or developing the online project? For web based applications (I assume by online you meant web based) there are better technologies available.
Regards,
Mohit
amohit is offline   Reply With Quote
Old 05-01-2012, 10:13 PM   #3 (permalink)
bijay_ps's Avatar
Regards,
Mohit
my main aim here is getting more experience on c/c++. So please help me
Old 05-01-2012, 11:10 PM   #4 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Well, for database connectivity you can use MySQL / PostgreSQL.
Just read the documentation and everything is mentioned there.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now   Reply With Quote
Old 06-01-2012, 01:28 PM   #5 (permalink)
Something Something
A_n_k_i_t's Avatar
Had done my final year project on C++ & DB Connectivity.
If you are using C/C++...you can use Oracle as a database...You will also need to know the concepts of Pro C.
Its helps in separating C/C++ & SQL language
Plus if you want to add graphics to you application,you can use ncurses.h & curses.h headers
Pro C Links
Click Here1
Click Here2
Click Here3
Click Here1
A_n_k_i_t is offline   Reply With Quote
Old 06-01-2012, 04:15 PM   #6 (permalink)
God of Mistakes...
Garbage's Avatar
If your main intension is to get more hands on on C/C++, then I would recommend developing any desktop (command line / GUI) application than web application. Creating web application is very very (mind you, very) hard starting point. For web application, you might want to use Java or .Net languages.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
Old 07-01-2012, 07:22 PM   #7 (permalink)
bijay_ps's Avatar
Pro C Links
Click Here1
Click Here2
Click Here3
Click Here1
thnx for the links
Hello there!! so when you say desktop application do you mean writing programs in C/C++ or something else? because I often write programs using this C language.
Old 08-01-2012, 11:39 AM   #8 (permalink)
God of Mistakes...
Garbage's Avatar
Yes, I mean writing programs using C/C++ and any desktop library for C/C++.
Old 09-01-2012, 05:20 AM   #9 (permalink)
bijay_ps's Avatar
Please tell me what is desktop library?? I don't know what it is?
Old 09-01-2012, 10:35 AM   #10 (permalink)
God of Mistakes...
Garbage's Avatar
Visit The GTK+ Project and Qt - Cross-platform application and UI framework — Qt - A cross-platform application and UI framework
