25-12-2011, 11:32 AM
Need help in Client server program
I want to implement a program in linux using c/c++ to implement client server architecture using pocket programming. It should be such that when a user
Stores a file on server the server slits the file and stores it on 2 or more server. Whenever user retrieves the file, the server retrieves the file again from different server forwards all the fragments to the user and display it in single file.
Please reply
visit my site: www.techdrome.blogspot.com
25-12-2011, 12:44 PM
BIOS Terminator
Re: Need help in Client server program
Please reply
that's socket programming
use socket() and connect() calls. here is an excellent tut Linux Howtos: C/C++ -> Sockets Tutorial
splitting and joining is easy file handling problem.
26-12-2011, 01:31 AM
NULL_PTR
google for beej's
Writing Mine Own Os
Wanna Join Pm ME
26-12-2011, 09:52 AM
guys but what about
"user stores a file on server the server slits the file and stores it on 2 or more server." Please help in this.
If possible can you code it for me because i dont know anything about socket and our professors are recklesss. they just say do it , they dont teach also
26-12-2011, 02:05 PM
BIOS Terminator
guys but what about
this is the case in all(most) colleges in India. so get used to it.
At least first go through that link i have given. it has very well explained sockets under Linux. Then attempt the program and if you face any problems, we are here to help.
26-12-2011, 02:52 PM
God of Mistakes...
First try to code simple program which stores a single file using the tutorial mentioned by nims11. Then post the code. Other members might help you in further coding.
07-01-2012, 12:53 PM
server.C program
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
void error(const char *msg)
perror(msg);
exit(1);
int main(int argc, char *argv[])
int sockfd, newsockfd, portno;
socklen_t clilen;
char buffer[256];
struct sockaddr_in serv_addr, cli_addr;
int n;
if (argc < 2) {
fprintf(stderr,"ERROR, no port provided\n");
exit(1);
sockfd = socket(AF_INET, SOCK_STREAM, 0);
if (sockfd < 0)
error("ERROR opening socket");
bzero((char *) &serv_addr, sizeof(serv_addr));
portno = atoi(argv[1]);
serv_addr.sin_family = AF_INET;
serv_addr.sin_addr.s_addr = INADDR_ANY;
serv_addr.sin_port = htons(portno);
if (bind(sockfd, (struct sockaddr *) &serv_addr,
sizeof(serv_addr)) < 0)
error("ERROR on binding");
listen(sockfd,5);
clilen = sizeof(cli_addr);
newsockfd = accept(sockfd,
(struct sockaddr *) &cli_addr,
&clilen);
if (newsockfd < 0)
error("ERROR on accept");
bzero(buffer,256);
n = read(newsockfd,buffer,255);
if (n < 0) error("ERROR reading from socket");
printf("Here is the message: %s\n",buffer);
n = write(newsockfd,"I got your message",18);
if (n < 0) error("ERROR writing to socket");
close(newsockfd);
close(sockfd);
return 0;
client.C
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <netdb.h>
perror(msg);
exit(0);
int sockfd, portno, n;
struct sockaddr_in serv_addr;
struct hostent *server;
char buffer[256];
if (argc < 3) {
fprintf(stderr,"usage %s hostname port\n", argv[0]);
exit(0);
portno = atoi(argv[2]);
if (sockfd < 0)
server = gethostbyname(argv[1]);
if (server == NULL) {
fprintf(stderr,"ERROR, no such host\n");
exit(0);
bcopy((char *)server->h_addr,
(char *)&serv_addr.sin_addr.s_addr,
server->h_length);
if (connect(sockfd,(struct sockaddr *) &serv_addr,sizeof(serv_addr)) < 0)
error("ERROR connecting");
printf("Please enter the message: ");
bzero(buffer,256);
fgets(buffer,255,stdin);
n = write(sockfd,buffer,strlen(buffer));
if (n < 0)
bzero(buffer,256);
n = read(sockfd,buffer,255);
if (n < 0)
printf("%s\n",buffer);
close(sockfd);
return 0;
now what to do , i want client to uplload file and server shud split it and send to other server and when user retrieves server should combine the parts and send to user
Reason: added code tags and removed duplicate entries
