Old 14-12-2011, 01:15 PM   #1 (permalink)
Rising Sun!
buddyram's Avatar
Default AJAX!!!
I need the help in modifying the ajax code in retrieving the data items from the database to the text field(like the google). As of now, I have put a <span> tag below the textfield with an Id for placing the data retrieved from the database
I have also attached the screenshot with an example!
“An expert is a man who tells you a simple thing in a confused way in such a fashion as to make you think the confusion is your own fault.” – William Castle
buddyram is online now   Reply With Quote
Old 14-12-2011, 02:08 PM   #2 (permalink)
BIOS Terminator
nims11's Avatar
Default Re: AJAX!!!
no AJAX expert, but try this.
put the text box in that <span> too and dynamically change its size to add and remove terms in the <span> below the text box.
Arch Linux is kind of a bonzai tree, over years u try new things, make small tweaks, and end up with a system that is unique, elegant, and does exactly what u designed it to do.
Hostapd : The Linux Way to create Virtual Wifi Access Point
My Blog
nims11 is online now   Reply With Quote
Old 21-12-2011, 05:53 PM   #3 (permalink)
Rising Sun!
buddyram's Avatar
Default Re: AJAX!!!
no it doesn't work!!
that textbox disappears when a character is keyed!!!
Old 22-12-2011, 09:47 AM   #4 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: AJAX!!!
@buddyram: I have done this type in AJAX...it is called autocomplete extender(works like google).
u can also do this in jquery (which will be faster than AJAX).
just use ajax autocomplete extender & u r done
Old 04-01-2012, 10:39 PM   #5 (permalink)
Rising Sun!
buddyram's Avatar
Default Re: AJAX!!!
^^sorry for the delayed response, i didn't notice your post
i'll try it
thanx
