Old 21-11-2011, 05:48 PM   #1 (permalink)
Default Help : Free Visual Studio Express 2010
Can Visual Studio Express 2010 used for developing & deploying Commercial Application ?
Requested to Highlight Limitation with respect to Visual Studio Professional 2010
gcbeldar is offline   Reply With Quote
Old 22-11-2011, 01:43 AM   #2 (permalink)
Default Re: Help : Free Visual Studio Express 2010
Express edition of VS can be used to develop commercial applications... Compared to Pro editions, it lacks some higher end features...
Arun
sakumar79 is offline   Reply With Quote
Old 22-11-2011, 07:57 AM   #3 (permalink)
Arun
Thanks for Reply, waiting for More Information from Other Members
Old 22-11-2011, 10:35 AM   #4 (permalink)
Fullbring
Zangetsu's Avatar
yes u can use express edition for development & deployment
Old 22-11-2011, 01:56 PM   #5 (permalink)
Resistance is Futile.
coolpcguy's Avatar
Yeah you can do commercial app development.
http://stackoverflow.com/q/86562/92837
The major areas where Visual Studio Express lacks features compared to Visual Studio Professional:
No add-ins/macros
Some Win32 tools missing
No Team Explorer support
Limited refactoring support
Debugging is much more limited (particularly problematic for server development is no remote debugging)
Lack of support for setup projects
No report creation tools
No Office development support
No mobile platform support
Limited set of designers
Limited set of database tools
No code profiling or test framework support
No MFC/ATL support
No support for compiling C++ to 64-bit images (workaround is to install Windows SDK which is free)
Super User ♦ Moderator | chip/tech2 forum Mod | About me
Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | Galaxy SII GT-I9100 | Dell U2312HM
coolpcguy is offline   Reply With Quote
Old 24-11-2011, 10:43 PM   #6 (permalink)
Hmm, Good Question.....
Lets Consider what you want to develop...
1.) If you are developing applications in Native/ISO Standard, then the express edition will do just fine.
2.) You are developing Windows applications using the MFC Libraries - In that case it won't work because MFC isn't bundled with express editions.
3.) You are developing applications using the CLI implementation, will be fine for simple applications but you will be severly lacking in complex ones..
BOTTOM LINE: Use Express editions to learn the language, for serious development get Professional or above
RahulB is offline   Reply With Quote
Old 26-11-2011, 08:15 AM   #7 (permalink)
1. For Developing small Applications like Account, Data Entry, Office Management, Hospital Management etc
Old 26-11-2011, 12:24 PM   #8 (permalink)
Express editions should do fine for small applications like these, you can do the design in VB, VC++ ( CLI ) and coding as well, with a database backend of SQL Server Express...
Salt and Pepper!
Old 30-12-2011, 03:37 PM   #9 (permalink)
★★★-DREADLORD-★★★
Skynaveen's Avatar
What coolpcguy said is very correct
It can be used to develop commercial apps
.Facebook vs Google Plus ----- poll/discussion (FIGHT CLUB)
http://www.thinkdigit.com/forum/figh...vs-google.html
Buying used or refurbished iPad: http://www.thinkdigit.com/forum/want...ml#post1615248
Skynaveen is offline   Reply With Quote
