Old 05-11-2011, 02:53 AM   #1 (permalink)
XLr8
arpanmukherjee1's Avatar
Default [Solved] Forum for ASP.net lisence issue
I have a working site in ASP.net 3.5 to which i want to add a discussion forum
found YAF (Yet another forum) and it is working fine but can i use it for commercial purpose for free ?????
if not whats other alternatives ?
arpanmukherjee1 is offline   Reply With Quote
Old 05-11-2011, 07:24 PM   #2 (permalink)
I'm a Wannabe Hacker
Prime_Coder's Avatar
Default re: [Solved] Forum for ASP.net lisence issue
Yet another Forum is licensed under GPL, so you can use it for commercial purpose also.
Do you know of Comm100 Forum ? You can get the Open Source version of it easily.
It suits your needs and requirements also. So, hope this helps you.
Prime_Coder is offline   Reply With Quote
Old 05-11-2011, 09:48 PM   #3 (permalink)
Arrow re: [Solved] Forum for ASP.net lisence issue
as long as you have copyright link to YAF i don't think it will have problem using it for commercial websites. check here.. Copyright Removal and Commercial Licenses | YetAnotherForum.NET
If you want to remove copy right YAF then you may need to purchase license.
HostASP is offline   Reply With Quote
Old 05-11-2011, 09:48 PM   #4 (permalink)
XLr8
i wanted an integrated forum that run in the application domain
YAF is current fullfilling all the needs.
i might add something later on according to needs of the company
thanks for the info.
i suppose the thread could be marked as SOLVED
