Old 04-10-2011, 10:12 AM   #1 (permalink)
learn more share more....
hacklinux's Avatar
Exclamation send mails using php
i need to send mails using php.how do i do that?
hacklinux is offline   Reply With Quote
Old 04-10-2011, 12:18 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: send mails using php
A simple google search would have revealed that.
Check PHP Mail for the idea.
And for more detail check PHP: mail - Manual
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now   Reply With Quote
Old 04-10-2011, 12:26 PM   #3 (permalink)
hacklinux's Avatar
i have read all those but dat doesnt seem to work.
Old 04-10-2011, 12:31 PM   #4 (permalink)
Simply a DIGITian
Ya, those works perfectly fine, check Spam mails, as you don't have proper header it may get into spam.
Old 04-10-2011, 12:39 PM   #5 (permalink)
hacklinux's Avatar
ya checked but doesnt work...any other possibilities?
Old 04-10-2011, 12:45 PM   #6 (permalink)
Simply a DIGITian
Are you sure..
<?php
$to = "someone@example.com";
$subject = "Test mail";
$message = "Hello! This is a simple email message.";
$from = "someonelse@example.com";
$headers = "From:" . $from;
mail($to,$subject,$message,$headers);
echo "Mail Sent.";
this program is not working??
It's working fine for me. Are you on Linux or using XAMPP / WAMP??
Old 04-10-2011, 12:47 PM   #7 (permalink)
hacklinux's Avatar
am using wamp...and should i download any smtp server fr dat?
Old 04-10-2011, 12:51 PM   #8 (permalink)
Simply a DIGITian
Nope, that should work fine. Don't know if there is any issue with WAMP itself.
I'd recommend to try XAMPP once if possible.
Otherwise you can use PHP Pear Mail package for SMTP Mail.
Old 04-10-2011, 01:04 PM   #9 (permalink)
hacklinux's Avatar
ok...ll do dat and let u knw....
in xampp it says "Warning: mail() [function.mail]: Failed to connect to mailserver at "localhost" port 25, verify your "SMTP" and "smtp_port" setting in php.ini or use ini_set() in C:\xampp\htdocs\mailf.php on line 7"
and on welcome page,der is a "status" option on right.in dat it says "SMTP service deactivated".has dis got to do anythng wid my problem?
Old 04-10-2011, 01:09 PM   #10 (permalink)
Simply a DIGITian
Can you please post your code??
Looks like you are not trying to send mails through internet instead you are trying to send mails through your mail server. Else WTH mail() will try to find SMTP Server on localhost.
Old 04-10-2011, 01:14 PM   #11 (permalink)
hacklinux's Avatar
<?php
$to = "hackpca@gmail.com";
$from = "urpcissafe@gmail.com";
echo "Mail Sent.";
Old 04-10-2011, 01:23 PM   #12 (permalink)
Simply a DIGITian
Check How to use sendmail in XAMPP for Windows | i.justrealized and try to add your mail id and password there from which you'd like to send the mail.
BTW that script has worked for me before without all these. Don't know if I'm also missing something.
Ahh figured it out I never did this from desktop. The mails scripts I've developed before was tried and tested on the server itself.
So you need to do that setting in php.ini as you need a authenticating SMTP server from which the mail will be sent. So that's must.
You can do the same in WAMP too.
Old 04-10-2011, 01:46 PM   #13 (permalink)
hacklinux's Avatar
wat do i give fr smtp_server,auth_username,auth_password?
Old 04-10-2011, 01:55 PM   #14 (permalink)
Simply a DIGITian
Yup.
10chars
Old 04-10-2011, 01:56 PM   #15 (permalink)
hacklinux's Avatar
sry m nt undrstanding dat part.wat values am i supposed to give der?
Old 04-10-2011, 09:34 PM   #16 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Use an SMTP relay like JangoSMTP.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline   Reply With Quote
Old 04-10-2011, 10:05 PM   #17 (permalink)
hacklinux's Avatar
ok i used.but after 4-5 mails i recieved error mails.and can i send mails to any mail id's or to oly the ones which i have added in jangosmtp?
Old 04-10-2011, 10:14 PM   #18 (permalink)
What kind of error?
Read this guide if it helps.
JangoMail In Progress: Technical Notes: Using the JangoMail API with PHP
Old 05-10-2011, 09:36 AM   #19 (permalink)
hacklinux's Avatar
System.Exception: This From Address ("postmaster@localhost") is not
allowed to send through this account.
at JangoEmlRelay.Relay.ProcessFile(Object o)
i get d above error as a mail from jango.
Old 05-10-2011, 09:42 AM   #20 (permalink)
Yes of course. Use a proper From E-Mail address. Like your actual E-Mail address.
Old 05-10-2011, 09:43 AM   #21 (permalink)
hacklinux's Avatar
but it worked fine wid frst 4-5 test mails....
Old 07-10-2011, 03:39 PM   #22 (permalink)
lol..last time when I did this, I preferred using a MTA like exim4.
