Old 09-09-2011, 02:43 PM   #1 (permalink)
Night Fury
mayoorite's Avatar
Exclamation Help in C++ programming!
HI!
I NEED C++ CODING TO MAKE A PATTERN USING NESTED LOOP.
I HAVE ATTACHED THE TEXT FILE FOR PATTERN.
PLEASE HELP ITS URGENT!!
mayoorite is offline
Old 09-09-2011, 03:17 PM   #2 (permalink)
gkbhat.blogspot.com
Default Re: Help in C++ programming!
I cannot see any pattern in the file Post a snapshot of the pattern and what have u tried to solve it
blogging at http://gkbhat.blogspot.com
gk2k is offline
Old 09-09-2011, 05:10 PM   #3 (permalink)
The Assassin
Cybertonic's Avatar
This ones pretty easy. First make a loop for the spaces at the left (i=0;i<=4;i++) and inside it make another loop for "& " (j=4;j>=0;j--).
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline
Old 09-09-2011, 07:36 PM   #4 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
12 hours you have to post your own attempt, doesn't matter it works or not but an honest attempt must be seen. Otherwise thread will be locked. No hand helding solutions, those posts will be deleted.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 09-09-2011, 08:08 PM   #5 (permalink)
Night Fury
mayoorite's Avatar
#include<iostream.h>
#include<conio.h>
main()
clrscr();
int i,j;
for(i=0;i<=4;i++)
{ for(j=4;j>=i;j--)
cout<<" &";
cout<<endl;
getch();
I don`t know how to increase 1 space in every loop.
please help!
Old 09-09-2011, 08:12 PM   #6 (permalink)
Try running a parallel inner loop which prints increasing amount of spaces (or tabs) with each increasing iteration. That is before the inner loop '&' executes, another loop executes which prints spaces ahead of it.
Last edited by Liverpool_fan; 09-09-2011 at 08:19 PM. Reason: Misunderstood ther question
Old 09-09-2011, 08:18 PM   #7 (permalink)
BIOS Terminator
nims11's Avatar
add a for loop before the for loop that prints the '&' to print number of spaces according to i.
nims11 is online now
Old 09-09-2011, 08:54 PM   #8 (permalink)
I am the night! I am....
vickybat's Avatar
@ mayoorite
Check the following buddy. Its prints a reverse equilateral triangle according to your needs.
#include<iostream>
using namespace std;
int main()
int n,i,space,column;
char a= '&';
cout<<"Enter the number of rows: "<<endl;
cin>>n;
for(i=n;i>0;i--)
      for(space=0;space<n-i;space++)cout<<" "; //assigning spaces
          cout<<a<<" "; //Writing the "&" character after assigning spaces
          for(column=i-1;column>0;column--)cout<<a<<" "; //writing the "&" character in the columns
          cout<<endl;
    cin.ignore();
     cin.get();
return 0;
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 09-09-2011, 08:58 PM   #9 (permalink)
Night Fury
mayoorite's Avatar
can anyone please write the code.
i am a beginner and have learned loops yesterday.
Old 09-09-2011, 09:24 PM   #10 (permalink)
BIOS Terminator
nims11's Avatar
for(int k=0;k<i;k++)
cout<<" ";
simply add this line just before the 2nd for loop of your program.
Old 09-09-2011, 10:06 PM   #11 (permalink)
Night Fury
mayoorite's Avatar
THANKS TO ALL FINALLY I GOT THE CORRECT WAY .
I HAVE USE THE BELOW CODE FOR IT.
#include<conio.h>
main()
	clrscr();
	int i,j,k,n;
	cout<<"Enter rows:";
	cin>>n;
	for(i=0;i<=n-1;i++)
		for(k=0;k<=i;k++)
		cout<<" ";
		for(j=n-1;j>=i;j--)
		cout<<" &";
		cout<<endl;
       getch();
LOOP->
Old 09-09-2011, 10:49 PM   #12 (permalink)
vickybat's Avatar
^^ Good job buddy. Keep practicing. C++ is very very interesting.
vickybat is offline
Old 10-09-2011, 12:53 AM   #13 (permalink)
gkbhat.blogspot.com
@OP: Glad that you where able to solve it. You think that you cannot do something until you do it.
gk2k is offline
Old 10-09-2011, 07:52 AM   #14 (permalink)
I guess the thread has run its course.
