Old 08-09-2011, 01:34 PM   #1 (permalink)
arian29's Avatar
Arrow need help with VBA
I need a code in vba which would read a file name in a specified folder (dynamic path). the file name changes every time and there can be more than one files and the code should pick them all. The file is recognised by a word say "QWE" which exists in the file name everytime. e.g. E2 QWE T556M.XLSX etc...
http://www.twitter.com/arian29
ScAn My AvAtAr
arian29 is offline   Reply With Quote
Old 08-09-2011, 04:12 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: need help with VBA
Sub Open_Files()
'//files are opened from here...and processed for raw data
Dim crnt_prj_pth As String
Dim fl_nm As String
fl_nm = Dir(crnt_prj_pth & "\" & "*.CSV") '//.CSV wildcard is being used here
Do While fl_nm <> "" '//master LOOP
'//intermediate processing
fl_nm = Dir
Loop
End Sub
This will cycle through the directory path which you assign to the variable "crnt_prj_pth".
asingh is online now   Reply With Quote
