Old 17-08-2011, 07:14 PM   #1 (permalink)
bijay_ps's Avatar
Default precedence between pre-increment and multipliction. how it works
I wrote this code
#include<stdio.h>
void main()
    int i,j;
    i=3;
    j=++i*++i*++i;
    printf("%d\n",j);
I am getting 216 as output in windows compiler and 150 in ubuntu compiler,but I anticipated that it should be 120.
So guys plz tell me how this code is working?? and one more thing this ++ oprtr has right to left associativity and * has left to right associativity.
Hey friends I figured it out,how its showing that result in windows (and when I say windows,I actually mean turbo-c compiler). But still can't understand how its showing 150 in ubuntu...... 'coz C lang. is same and concept cannot differ from OS to OS,only syntax may differ a little. So plz help me out here.....
Follow 7H3 G33K !nside YOU
bijay_ps is offline   Reply With Quote
Old 18-08-2011, 07:11 AM   #2 (permalink)
Default Re: precedence between pre-increment and multipliction. how it works
This behaviour can vary from compiler to compiler. I don't know why Yindan teachers and books by incompetent writers like Yashwant Kanetkar and Sumita Arora ask such questions.
Old 18-08-2011, 09:18 PM   #3 (permalink)
bijay_ps's Avatar
Sorry my friend but I think each question has its own importance and worth.
I'm interested in knowing the answer only.....
Old 19-08-2011, 05:57 PM   #4 (permalink)
First thing stop using Turbo C or Turbo C as your Windows compiler, instead use GNU C Compiler, Microsoft Visual C Compiler.
Ubuntu uses GNU C Compiler (gcc) which is an updated compiler supporting ANSI C while Turbo C is decades old and doesn't support ANSI C rather it supports old C (i think K&R C). As ANSI C is somewhat different from old C, so you are getting different answers.
Stop reading books like Let us C etc. These are out-dated ones. Read books which supports ANSI C like Programing in ANSI C by Denis M. Ritchie.
abhijangda is online now   Reply With Quote
Old 23-08-2011, 05:19 PM   #5 (permalink)
bijay_ps's Avatar
I don't know why you guys are thinking that I am reading Let Us C....... FYI I am following Complete refrence....... and I came across this question 'coz one of my frnd asked me this
Old 24-08-2011, 09:44 AM   #6 (permalink)
gkbhat.blogspot.com
According to the C standard the behavior when increment a variable and using it in within a single sequence point is undefined and is dependent on the individual compiler implementation.
Turbo C all the three increments are performed before the multiplication operation i.e j=6*6*6
In gcc the expression is split as j=(++i*++i)*++i. i.e a sequence point is inserted before the second multiplication so the resultant operation is j=(5*5)*6. Here two increments are performed before the first multiplication so i=5.
blogging at http://gkbhat.blogspot.com
gk2k is offline   Reply With Quote
Old 24-08-2011, 07:18 PM   #7 (permalink)
because Let us C follows Turbo C.
Old 24-08-2011, 07:36 PM   #8 (permalink)
And I've actually given you the answer. This is a compiler specific behaviour. The answer will vary in each compiler you use.
@abhijangda: He might not be following 'Let Us C' that was just my random rant against Yindan teacher/authors who as pre and post increment questions.
Old 29-08-2011, 09:42 AM   #9 (permalink)
bijay_ps's Avatar
Thanks for beautiful explanation now I understood the concept fully........ thnx once again
thnx for Ur reply too...... now I got the concept
