Hey,
i needed help writing a program.
the program's concept is that it inputs a string and then replaces the following in the string and gives the output:
q with a
w with s
e with d
r with f
t with g
y with h
u with j
i with k
o with l
p with p
a with z
and so on.
When god creatd me, he was just showing off...
1. Which Programming language?
2. What kind of interface will the program have? Console based, Web, GUI, etc.
3. Post an attempt, even a failed/incomplete one will do, otherwise this thread will be locked. You've 24 hours.
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
You just had to post your code in [PHP] [/PHP] or [CODE] [/CODE] . Since you failed in that part, so thread closed. You are free to create a proper thread next time.
