Old 24-07-2011, 10:47 PM   #1 (permalink)
CSE Freak!
rajsujayks's Avatar
Exclamation How to make the program produce the required output..?
I want to get the input and output as in the files attached.
This is my code:
//Employee Details...
//Execution syntax : "ProgramName InputFile OutputFile"
//Input File should contain grade and name of employee
//separated by a tab with one record per line..
#include <stdio.h>
#include <string.h>
int main(int argc,char *argv[])
    FILE *in,*out;
    char *name,*designation;
    float basic,hra,da,gross;
    char grade;
    //Opening files..
    in=fopen(argv[1],"r");
    out=fopen(argv[2],"w");
    if((in==NULL)||(out==NULL))
        printf("\n\nEither one or both the specified files cannot be opened!");
        return 0;
    while(feof(in)==0)
        basic=10000;
        fscanf(in,"%c%s",&grade,name);
        switch(grade)
            case 'E':
                strcpy(designation,"Engineer");
                hra=0.15;
                da=0.10;
                break;
            case 'S':
                strcpy(designation,"Supervisor");
                hra=0.20;
                da=0.10;
                break;
            case 'P':
                strcpy(designation,"Project Head");
                hra=0.25;
                da=0.15;
                break;
            case 'H':
                strcpy(designation,"Helper");
                hra=0.10;
                da=0.05;
                break;
            default:
                strcpy(designation,"Unknown");
                hra=0;
                da=0;
        gross=basic+(basic*hra)+(basic*da);
        fprintf(out,"%s\t%s\t%f",name,designation,gross);
    fclose(in);
    fclose(out);
    printf("\n\n\tFile %s generated!",argv[2]);
    return 0;
That is, if I give the command
C:\>emp empin.txt empout.txt
(assuming the file empin.txt is in C: drive and the code is compiled and saved in the name emp.exe in C: drive), the attached file should be produced...
Please check and tell me what I'm doing wrong. Thanks in advance.
File Type: txt EMPIN.txt (46 Bytes, 7 views)
File Type: txt EMPOUT.txt (115 Bytes, 7 views)
Dell Inspiron 530 desktop | Intel C2Q Q6600 @ 2.4 Ghz | 2GB DDR2 667Mhz | ASUS ENGTS450 | 250GB SATA2 | Windows 7 Ultimate 64-bit | 350 watt PSU | HP Deskjet F4488 AllInOne | Nokia 6681 Sony Ericsson XPERIA MiniPro (Love you Nokia..! :-( Am sorry..)
rajsujayks is offline   Reply With Quote
Old 25-07-2011, 11:25 PM   #2 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Default Re: How to make the program produce the required output..?
Well first of all
These are simply character pointers and you haven't allocated any memory. Either statically allocate some highest possible size using arrays or dynamically allocate memory.
Secondly don't use "%c" in fscanf and in particular don't mix it with %s.
Either use the incredibly hackish way of %1s and pointer to character in fscanf, or just use fgets to read the line and then parse it.
Just don't mix characters and strings, it can get ugly.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline   Reply With Quote
Old 26-07-2011, 10:12 PM   #3 (permalink)
CSE Freak!
rajsujayks's Avatar
Exclamation Re: How to make the program produce the required output..?
Originally Posted by Liverpool_fan View Post
Well first of all
Tried... But it doesn't seem to work..Something else is wrong I guess...
Well first of all
NO! NO! It works...! Thanks a lot..! I fumbled with the code for about 2 hours and got it...! I always love that feeling.. ! Thank YOU!!
