Old 30-06-2011, 07:05 PM   #1 (permalink)
Default Building a firewall from scratch
Hi Guys! I am trying to develop a firewall from scratch in linux environment using C. Actually its more of a Unified Threat Management sysytem .I need some help in deciding which features to include like antispam, content filtering, vulnerability analyzing,etc. I have exactly 1 year to complete this project so please suggest which features can be coded completely in time.
I also need help in getting started. Actually I have broken the process of development in 4 stages namely :
1. Capture the packet (using libcap)
2. Break the packet into headers and data (using libpcap)
3. Analyze the headers and data and make a decision
4. ACCEPT or DROP the packet (using netfilter in linux)
Its the third step that will depend on the features which are included in the project. I plan to code using the UNIX Socket API.
Please help me out here in getting started.
Thanks in advance
kaidranzer is offline   Reply With Quote
Old 30-06-2011, 08:10 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: Building a firewall from scratch
It seems that you have made your mind for developing a packet filtering firewall. But if you don't know about other types of firewalls, I would recommend you reading - Firewall (computing) - Wikipedia, the free encyclopedia
Secondly, you can look at some of the Open source firewall / threat management systems such as
pfSense Open Source Firewall Distribution - Home
Express Open Source Firewall Project
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
Old 30-06-2011, 10:40 PM   #3 (permalink)
Yes, packet filtering is what I plan but what I am thinking of doing is breaking a packet into headers and data. Header analysis will be the "packet-filtering firewall" kind of thing and analyzing the data would be an "application-layer firewall" kind of thing.
I need to know whether I am on the right track.
Old 01-07-2011, 10:11 AM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
^^ IMO, as soon as you start looking at packets, you have a packet filtering firewall. Building an application layer firewall should be inherently different than building a packet filtering firewall.
BTW, here are some codes which you can look at before you start writing yours.
Express Open Source Firewall Project » Sources
https://rcs.pfsense.org/projects/pfsense // https://github.com/bsdperimeter/pfsense
