Old 27-06-2011, 10:28 AM   #1 (permalink)
learn more share more....
hacklinux's Avatar
Question regarding python
i am learning python and just learnt few basics.now i need to save a file and run it.how do i do it?
hacklinux is offline   Reply With Quote
Old 27-06-2011, 10:45 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: regarding python
Save the file with .py as extension. So if you name the file helloworld then the file name should be helloworld.py
Now from the terminal, invoke that file using
python helloworld.py
and press enter.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now   Reply With Quote
Old 27-06-2011, 11:00 PM   #3 (permalink)
hacklinux's Avatar
ok...dats fine but where do i save it?in d folder where my python main files are,over der?
Old 27-06-2011, 11:34 PM   #4 (permalink)
Anish's Avatar
^ You can save it any where you like. But while running the command in terminal be sure you are in the location where you saved your file.
The secret ingredient is nothing
Anish is offline   Reply With Quote
Old 28-06-2011, 12:42 PM   #5 (permalink)
hacklinux's Avatar
i downloaded few codes from few websites and tried running them but they display some kind of error and am not able to understand why it is showing error.
Old 28-06-2011, 01:12 PM   #6 (permalink)
Manchester United <3
Ishu Gupta's Avatar
What's the error?
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 28-06-2011, 01:13 PM   #7 (permalink)
Simply a DIGITian
Because the programs are wrong. For understanding those errors you need to learn Python.
Old 28-06-2011, 01:15 PM   #8 (permalink)
Ishu Gupta's Avatar
I have a feeling that he has not installed python.
Old 28-06-2011, 01:22 PM   #9 (permalink)
hacklinux's Avatar
i have this tic-tac-toe game here.downloaded from the internet.
# Tic Tac Toe
import random
def drawBoard(board):
    # This function prints out the board that it was passed.
    # "board" is a list of 10 strings representing the board (ignore index 0)
    print('   |   |')
    print(' ' + board[7] + ' | ' + board[8] + ' | ' + board[9])
    print('   |   |')
    print('-----------')
    print('   |   |')
    print(' ' + board[4] + ' | ' + board[5] + ' | ' + board[6])
    print('   |   |')
    print('   |   |')
    print(' ' + board[1] + ' | ' + board[2] + ' | ' + board[3])
    print('   |   |')
def inputPlayerLetter():
    # Let's the player type which letter they want to be.
    # Returns a list with the player's letter as the first item, and the computer's letter as the second.
    letter = ''
    while not (letter == 'X' or letter == 'O'):
        print('Do you want to be X or O?')
        letter = input().upper()
    # the first element in the tuple is the player's letter, the second is the computer's letter.
    if letter == 'X':
        return ['X', 'O']
    else:
        return ['O', 'X']
def whoGoesFirst():
    # Randomly choose the player who goes first.
    if random.randint(0, 1) == 0:
        return 'computer'
    else:
        return 'player'
def playAgain():
    # This function returns True if the player wants to play again, otherwise it returns False.
    print('Do you want to play again? (yes or no)')
    return input().lower().startswith('y')
def makeMove(board, letter, move):
    board[move] = letter
def isWinner(bo, le):
    # Given a board and a player's letter, this function returns True if that player has won.
    # We use bo instead of board and le instead of letter so we don't have to type as much.
    return ((bo[7] == le and bo[8] == le and bo[9] == le) or # across the top
    (bo[4] == le and bo[5] == le and bo[6] == le) or # across the middle
    (bo[1] == le and bo[2] == le and bo[3] == le) or # across the bottom
    (bo[7] == le and bo[4] == le and bo[1] == le) or # down the left side
    (bo[8] == le and bo[5] == le and bo[2] == le) or # down the middle
    (bo[9] == le and bo[6] == le and bo[3] == le) or # down the right side
    (bo[7] == le and bo[5] == le and bo[3] == le) or # diagonal
    (bo[9] == le and bo[5] == le and bo[1] == le)) # diagonal
def getBoardCopy(board):
    # Make a duplicate of the board list and return it the duplicate.
    dupeBoard = []
    for i in board:
        dupeBoard.append(i)
    return dupeBoard
def isSpaceFree(board, move):
    # Return true if the passed move is free on the passed board.
    return board[move] == ' '
def getPlayerMove(board):
    # Let the player type in his move.
    move = ' '
    while move not in '1 2 3 4 5 6 7 8 9'.split() or not isSpaceFree(board, int(move)):
        print('What is your next move? (1-9)')
        move = input()
    return int(move)
def chooseRandomMoveFromList(board, movesList):
    # Returns a valid move from the passed list on the passed board.
    # Returns None if there is no valid move.
    possibleMoves = []
    for i in movesList:
        if isSpaceFree(board, i):
            possibleMoves.append(i)
    if len(possibleMoves) != 0:
        return random.choice(possibleMoves)
    else:
        return None
def getComputerMove(board, computerLetter):
    # Given a board and the computer's letter, determine where to move and return that move.
    if computerLetter == 'X':
        playerLetter = 'O'
    else:
        playerLetter = 'X'
    # Here is our algorithm for our Tic Tac Toe AI:
    # First, check if we can win in the next move
    for i in range(1, 10):
        copy = getBoardCopy(board)
        if isSpaceFree(copy, i):
            makeMove(copy, computerLetter, i)
            if isWinner(copy, computerLetter):
                return i
    # Check if the player could win on his next move, and block them.
            makeMove(copy, playerLetter, i)
            if isWinner(copy, playerLetter):
                return i
    # Try to take one of the corners, if they are free.
    move = chooseRandomMoveFromList(board, [1, 3, 7, 9])
    if move != None:
        return move
    # Try to take the center, if it is free.
    if isSpaceFree(board, 5):
        return 5
    # Move on one of the sides.
    return chooseRandomMoveFromList(board, [2, 4, 6, 8])
def isBoardFull(board):
    # Return True if every space on the board has been taken. Otherwise return False.
            return False
    return True
print('Welcome to Tic Tac Toe!')
while True:
    # Reset the board
    theBoard = [' '] * 10
    playerLetter, computerLetter = inputPlayerLetter()
    turn = whoGoesFirst()
    print('The ' + turn + ' will go first.')
    gameIsPlaying = True
    while gameIsPlaying:
        if turn == 'player':
            # Player's turn.
            drawBoard(theBoard)
            move = getPlayerMove(theBoard)
            makeMove(theBoard, playerLetter, move)
            if isWinner(theBoard, playerLetter):
                drawBoard(theBoard)
                print('Hooray! You have won the game!')
                gameIsPlaying = False
            else:
                if isBoardFull(theBoard):
                    drawBoard(theBoard)
                    print('The game is a tie!')
                    break
                else:
                    turn = 'computer'
        else:
            # Computer's turn.
            move = getComputerMove(theBoard, computerLetter)
            makeMove(theBoard, computerLetter, move)
            if isWinner(theBoard, computerLetter):
                drawBoard(theBoard)
                print('The computer has beaten you! You lose.')
            else:
                    drawBoard(theBoard)
                    break
                else:
                    turn = 'player'
    if not playAgain():
        break
end....
the error i get is dis
Traceback (most recent call last):
File "C:\examples\tictactoe.py", line 145, in <module>
File "C:\examples\tictactoe.py", line 27, in inputPlayerLetter
File "<string>", line 1, in <module>
NameError: name 'x' is not defined
now wat is d problem?can u help me wid it?
Old 28-06-2011, 01:57 PM   #10 (permalink)
Ishu Gupta's Avatar
Try using Python 3.
Old 28-06-2011, 02:04 PM   #11 (permalink)
hacklinux's Avatar
tried..even den it says d same...
Old 28-06-2011, 03:18 PM   #12 (permalink)
Ishu Gupta's Avatar
# Tic Tac Toe
import random
    print('   |   |')
    print('   |   |')
    print('   |   |')
    print('   |   |')
    print('   |   |')
    print('   |   |')
    letter = ''
        letter = raw_input().upper()
    if letter == 'X':
        return ['X', 'O']
    else:
        return ['O', 'X']
def whoGoesFirst():
        return 'computer'
    else:
        return 'player'
def playAgain():
    return raw_input().lower().startswith('y')
    dupeBoard = []
    for i in board:
        dupeBoard.append(i)
    return dupeBoard
    move = ' '
        move = raw_input()
    return int(move)
    possibleMoves = []
    for i in movesList:
    else:
        return None
        playerLetter = 'O'
    else:
        playerLetter = 'X'
                return i
                return i
    if move != None:
        return move
        return 5
            return False
    return True
while True:
    # Reset the board
            # Player's turn.
            drawBoard(theBoard)
                drawBoard(theBoard)
            else:
                    drawBoard(theBoard)
                    break
                else:
                    turn = 'computer'
        else:
            # Computer's turn.
                drawBoard(theBoard)
            else:
                    drawBoard(theBoard)
                    break
                else:
                    turn = 'player'
    if not playAgain():
        break
Old 07-02-2012, 01:09 PM   #13 (permalink)
i love bakwaas
Seems like an old thread but i don't know where else to ask.
Trying something like this Wu-Name Name Generator in python.
Help or guidance would be greatly appreciated.
kaput is offline   Reply With Quote
Old 09-02-2012, 08:00 PM   #14 (permalink)
Anish's Avatar
Follow these two steps:
1. Buy the book - Head first python
2. Read the book
You will be a excellent programmer in python when you finish the book - believe me
Old 10-02-2012, 12:35 PM   #15 (permalink)
i love bakwaas
will buy soon
About my earlier post, i got around to that part where i can generate random names. But even for the same input string it generates a different name.
eg input :Mohan output : cool guy
eg: input: Mohan output: creepy man
any idea how to get the same output for the same input.
Old 10-02-2012, 10:01 PM   #16 (permalink)
Anish's Avatar
^ Can you post the code so that we can rectify it?
Old 13-02-2012, 10:58 AM   #17 (permalink)
i love bakwaas
using college library computer.
will post soon. thanks
