Old 21-06-2011, 10:33 PM   #1 (permalink)
bijay_ps's Avatar
Default Path setting for .net framework4
Hey frndz am using .net framework 4 for c# programing.... and visual studio 2010 also. But for programs in which i need to supply command line argument gives error in visual studio 2010, so i thought of setting my path in environment variable,so that i can do it from cmd prompt. But even after setting path when I went to cmd and typed csc -? to check if path has been set correctly?
it didn't recognized the command.
So can anyone tell me a stepwise procedure for setting the path?
Follow 7H3 G33K !nside YOU
bijay_ps is offline   Reply With Quote
Old 23-06-2011, 09:32 AM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: Path setting for .net framework4
in cmd type in
%comspec% /k ""G:\Program Files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat"" x86
it sets env for x86 .
or else replace x86 by :
amd64
x64
ia64
x86_amd64
x86_ia64
arpanmukherjee1 is offline   Reply With Quote
Old 25-06-2011, 08:39 PM   #3 (permalink)
bijay_ps's Avatar
thnx alot
