Old 26-05-2011, 03:09 PM   #1 (permalink)
Default Emergency PHP Script Need Help Adding Feature
Okay, I have a emergency dispatching script and I implemented a "Emergency" feature, the emergency feature allows a company to hit the emergency button if they are in distress. The dispatcher and I have ran through multiple test, sometimes even random test. And during the random test the emergency button was activated for over 30 minutes before the dispatcher noticed. I'm looking to make it so that if the emergency button is activated then a pop-up will appear on the dispatchers screen saying "{UNIT} has activated their emergency banner". I'm not sure what all information is needed for you guys/gals to help me.
If you can try to help I would appreciate that, please send a PM or post here. Thank you in advance.
bagsfr is offline   Reply With Quote
