Old 12-05-2011, 11:51 AM   #1 (permalink)
arian29's Avatar
Default need logic in vba
i need the logic in vba(using any loops) for this >
if col A has repeted vales then col B should have the first instance value for such repetations as x and rest as y. basically i need to populate col B in this way, col A is only present.
eg,
A B
2 x
2 y
1 y
3 x
3 y
3 y
http://www.twitter.com/arian29
ScAn My AvAtAr
arian29 is offline   Reply With Quote
Old 12-05-2011, 12:04 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: need logic in vba
The first instance of 2 = x, for 1 = y, how can 3 = y again.
Give me the logic more clear, will help.
asingh is online now   Reply With Quote
Old 12-05-2011, 12:08 PM   #3 (permalink)
arian29's Avatar
No its not that 2 = anything. Nothing is equal to anything. There are 2 columns A and B. Column A is already populated with the given numbers. some numbers are repeted like number 2 and 3. 2 is always repeted twice and 3 is repeted thrice. now i want x in column B , against the first instance of 2 or 3 and y against the rest of the instances. So i am filling column B.
its in vba (excel)
Thanks
ScAn My AvAtAr
Old 12-05-2011, 12:16 PM   #4 (permalink)
Super Moderator
asingh's Avatar
But this logic will not apply to the first instance of '1'..?
Only for '2' and '3'.
Old 12-05-2011, 12:20 PM   #5 (permalink)
arian29's Avatar
ya.. actually the data in column A is like
1
2
2
1
1
1
1
3
3
3
1
1
2
2
1
2
2
1
1
3
3
3
1
1
1
3
3
3
1
2
2
like this.. so i need x against the 'first' instance of 2 and 3. getting y against 1 is easy as there is only one instance but having problem with 2 and 3. rest of the instances will have a y.
ScAn My AvAtAr
Old 12-05-2011, 12:27 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by arian29 View Post
eg,
A B
2 x
2 y
1 y
3 x
3 y
3 y
I think the e.g is like this
A B
2 x
2 y
1 x
3 x
3 y
3 y
Old 12-05-2011, 12:30 PM   #7 (permalink)
arian29's Avatar
you can have x or y against 1, dosent matter, prob is with 2 and 3.
ScAn My AvAtAr
Old 12-05-2011, 01:46 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Would a formulaic approach work here......
I pasted the data from post number 5 on a range of D10 : D40.
Then I wrote this formula in E10:
=IF(COUNTIF($D$10 : D10,D10)=1,"x","y")
Once you type the last bracket, press CONTROL+SHIFT+ENTER, and the formula will get {} around it.
Now double click down..>!
Old 12-05-2011, 02:44 PM   #9 (permalink)
arian29's Avatar
no its not working..
ScAn My AvAtAr
Old 12-05-2011, 03:08 PM   #10 (permalink)
Fullbring
Zangetsu's Avatar
sorry i m n00b in vba.But
the logic will be like this
consider range of column A is A1:A20 => output will be B1:B20
start from A1 -> store it in a temp variable
Read A2 cell value & compare it with the temp variable if = then put y else put x
this will go on till A20
temp variable will always store the previous cell value
Old 12-05-2011, 04:26 PM   #11 (permalink)
abhidev's Avatar
I don't think this logic will work...coz what happens if any of those numbers repeat in the sequence....e.g 1 2 2 2 3 3 3 1 1 1 2 2 2....correct me if I am wrong...the output for this sequence should be x x y y x y y y y y y y y ...right?
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is online now   Reply With Quote
Old 12-05-2011, 04:53 PM   #12 (permalink)
Super Moderator
asingh's Avatar
Yes, because you did not follow the way I asked you to.
There is absolutely no USE for VBA for this. VBA is used only when native excel cannot do the job.
Please see the sheet I have attached. Look at the yellow cells, and understand the formula I wrote. It is an array function, and does the job perfect.
Sample.xls - 4shared.com - online file sharing and storage - download
And I repeat again, there is no need to do this with VBA. It is shooting a fly with a cannon. Unless your data is crossing 50,000 rows or something.
