08-05-2011, 01:17 PM
problem in PyQt4 program
Hello everyone, I have started creating a Download Manager for Linux using Python with PyQt4 as GUI toolkit and PycURL as library for downloading files. My problem is that whenever I start a download GUI stops. It works in the background and just keeps on downloading but no response from GUI.
Code is Here.
main.py
from PyQt4 import QtCore,QtGui
import downloadclass,winaddnew,treeitem
import sys
class Downloader(QtGui.QMainWindow):
def __init__(self,parent=None):
QtGui.QMainWindow.__init__(self,parent)
self.setWindowTitle("Download")
self.setGeometry(10,10,600,400)
self.tablewidget = QtGui.QTableWidget(self)
self.setCentralWidget(self.tablewidget)
self.tablewidget.setColumnCount(6)
self.tablewidget.setHorizontalHeaderLabels(['File Name','Url','Size','Downloaded','Time Remaining','Speed','Status'])
self.tablewidget.setRowCount(1)
self.tablewidgetrowitemarray = []
self.tablewidget.horizontalHeader().setClickable(False)
self.tablewidget.cellClicked.connect(self.cellclicked)
menubar = self.menuBar()
newdownload = QtGui.QAction("Create a new download",self)
start = QtGui.QAction("Start",self)
stop = QtGui.QAction("Stop",self)
pauseresume = QtGui.QAction("Pause/Resume",self)
startall = QtGui.QAction("Start All",self)
stopall = QtGui.QAction("Stop All",self)
pauseresumeall = QtGui.QAction("Pause/Resume All",self)
restart = QtGui.QAction("Restart Download",self)
downloadmenu = menubar.addMenu("Download")
downloadmenu.addAction(newdownload)
downloadmenu.addAction(start)
downloadmenu.addAction(stop)
downloadmenu.addAction(pauseresume)
downloadmenu.addAction(startall)
downloadmenu.addAction(stopall)
downloadmenu.addAction(pauseresumeall)
downloadmenu.addAction(restart)
self.addwin = winaddnew.addnewwin()
self.url = ''
self.path = ''
self.filename = ''
self.rowselected = 0
self.downloaditem = treeitem.downloaditem
self.dwlclass = downloadclass.downloadfile
self.downloaditemarray = []
self.connect(newdownload,QtCore.SIGNAL('triggered()'),self.funcshowaddwin)
self.connect(start,QtCore.SIGNAL('triggered()'),self.funcstart)
self.Timer = QtCore.QTimer(self)
self.Timer.setInterval(200)
self.connect(self.Timer, QtCore.SIGNAL('timeout()'),self.functimer)
def cellclicked(self,row,col):
self.tablewidget.selectRow(row)
self.rowselected = row
def funcshowaddwin(self):
self.Timer.start()
self.addwin.show()
def functimer(self):
self.url,self.path = self.addwin.funcpass()
if self.url != '':
if self.path !='':
self.Timer.stop()
self.adddownload()
def adddownload(self):
self.downloaditemarray.append(self.downloaditem(self.getfilename(self.url),self.url,0,'Downloading'))
self.createrow(self.downloaditemarray[len(self.downloaditemarray)-1])
def createrow(self,downloaditem):
for i in range(0,6):
self.tablewidgetrowitemarray.append(QtGui.QTableWidgetItem(0))
self.tablewidgetrowitemarray[i].setFlags(QtCore.Qt.ItemIsSelectable)
self.tablewidget.setItem(0,i,self.tablewidgetrowitemarray[i])
self.tablewidgetrowitemarray[0].setText(downloaditem.filename)
self.tablewidgetrowitemarray[1].setText(downloaditem.url)
self.tablewidgetrowitemarray[2].setText(str(downloaditem.size))
self.tablewidgetrowitemarray[3].setText("")
self.tablewidgetrowitemarray[4].setText("")
self.tablewidgetrowitemarray[5].setText("")
#self.tablewidgetrowitemarray[6].setText(downloaditem.status)
def getfilename(self,url):
lst = url.split('/')
return lst[len(lst)-1]
def funcstart(self):
d = self.dwlclass(self.path,str(self.tablewidget.item(self.rowselected,1).text()),self.tablewidget.item(self.rowselected,2).text())
self.tablewidgetrowitemarray[2].setText(str(d.size))
d.start()
app = QtGui.QApplication(sys.argv)
d = Downloader()
d.show()
app.exec_()
downloadclass.py
import pycurl,os
class downloadfile(object):
def __init__(self,path,url,downloaded):
self.url = url
self.path = path
self.downloaded = downloaded
self.size = 0
self.bytesdownloaded = 0
self.initial = 0
self.final = 0
self.curl = pycurl.Curl()
self.curl.setopt(pycurl.URL,self.url)
def progress(self,download_t,download_d,upload_t,upload_d):
self.initial = download_d
self.size = download_t
self.bytesdownloaded = download_d
self.speed = self.final - self.initial
self.final = download_d
def start(self):
f = open(self.path,"wb")
self.curl.setopt(pycurl.WRITEDATA,f)
self.curl.setopt(pycurl.NOPROGRESS,0)
self.curl.setopt(pycurl.PROGRESSFUNCTION,self.progress)
self.curl.perform()
def resume(self):
f = open(self.path,"ab")
self.curl.setopt(pycurl.RESUME_FROM,os.path.getsize(self.path))
self.curl.setopt(self.pycurl.WRITEDATA,f)
self.curl.perform()
Can anyone solve my problem or atleast give me a hint??
09-05-2011, 12:47 AM
Commander in Chief
Re: problem in PyQt4 program
You're downloading within the application's thread. That would block it, naturally.
Try threading out your downloader operations as a solution, making it report some progress only when required. It would be a good exercise to add to your skill-building.
Harsh J
www.harshj.com
09-05-2011, 12:51 AM
Thanks for reply, are you talking about threads in python??
09-05-2011, 01:19 AM
Commander in Chief
Yes, you should be able to use Python's own threads over QThreads. However, the latter supports the whole signals-and-slots concept, if you swing that way.
Harsh J
www.harshj.com
09-05-2011, 09:04 AM
gkbhat.blogspot.com
You should use threading. I do not know about Python threads, but QThread can do the job very well for you.
blogging at http://gkbhat.blogspot.com
09-05-2011, 10:42 AM
thanks for reply!!
