Old 24-04-2011, 09:59 PM   #1 (permalink)
Unhappy How to store multiple values of CheckBoxList? in ASP.net
I am creating a webpage using ASP.net(c#)
I have inserted a CheckBoxList inside the webpage like below
Interested in
  • Friends
  • Dating
  • Business
  • Activity Partners
where multiple values can be selected
when I click on the submit button,I want to store multiple selected values (text) in the database in a single coulmn.
and when next time the page_Load event fires,I want the multiple values to be fetched using select statement & the stored values must be selected in the CheckBoxList
My idea is to use a String datatype to store multiple values of CheckBoxList by concating & to use substring to fetch & select the multiple items
But I can't do it
Please help me...
binay00713 is offline   Reply With Quote
Old 24-04-2011, 11:55 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: How to store multiple values of CheckBoxList? in ASP.net
Well, I'd say concatenate the strings using some delimiter and then split them based on that delimiter.
Say for Eg, concatenate with comma(,)
Friends,Dating,Business
Now split it with
s.Split(',');
where s is the string which contains "Friends,Dating,Business"
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now   Reply With Quote
Old 27-04-2011, 08:46 PM   #3 (permalink)
XLr8
arpanmukherjee1's Avatar
> button1 = Submit
> instead using Session, query the DB
    protected void Page_Load(object sender, EventArgs e)
        if (Page.IsPostBack && Session["data"]!=null)
            foreach (string s in Session["data"].ToString().Split(new Char[] { ',' }, StringSplitOptions.RemoveEmptyEntries))
                foreach (ListItem l in CheckBoxList1.Items)
                    if (l.Text == s)
                        l.Selected = true;
    protected void Button1_Click(object sender, EventArgs e)
        foreach (ListItem val in CheckBoxList1.Items)
            if (val.Selected)
                Session["data"] += val.Text + ",";
            l.Selected = false;
arpanmukherjee1 is offline   Reply With Quote
Old 28-04-2011, 12:11 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
@binay00713: just create a stored procedure & pass the selected values in string as ',' separated.
use column datatype a varchar
& while fetching the data use another stored procedure which returns a Table
& use split function to return comma separated values in Table form
