Old 31-03-2011, 08:32 PM   #1 (permalink)
bijay_ps's Avatar
Unhappy doubt between fscanf and fgets
whats the difference between fscanf and fgets in file handling(In C)?
Follow 7H3 G33K !nside YOU
bijay_ps is offline   Reply With Quote
Old 31-03-2011, 11:54 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: doubt between fscanf and fgets
fscanf does not perform bounds checking. fgets is likely going to be the better choice. You can then use sscanf() to evaluate it.
more info
IBM TPF Product Information Center
fscanf - C++ Reference
fgets - C++ Reference
scanf vs fgets?
BTW one more thing, never use scanf for input, use cin. Google it up if u want to know why, too many reasons for me to type
arpanmukherjee1 is offline   Reply With Quote
Old 01-04-2011, 10:24 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Why suggest std::cin when the OP is using C, and confuse him?
Harsh J
www.harshj.com
QwertyManiac is offline   Reply With Quote
Old 01-04-2011, 11:05 AM   #4 (permalink)
XLr8
^^ yes i thought it too
but the advantage(s) of C++ over C must be kept in mind
Old 01-04-2011, 12:07 PM   #5 (permalink)
bijay_ps's Avatar
thanks guys....
Old 01-04-2011, 12:40 PM   #6 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Not sure how std::cin can be an advantage of C++ over C? Only advantage I can think of that you have to specify the format for the input in scanf which is not needed in std::cin. However both exhibit similar behaviour since they are usually implemented as line buffered.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline   Reply With Quote
Old 01-04-2011, 10:35 PM   #7 (permalink)
XLr8
^^ yes that, i'am sorry about the post.
i should have explained it.
reading this post now, i sound a lot like my coll professors
u explained it very well. thankyou
