Old 25-03-2011, 06:47 PM   #1 (permalink)
BIOS Terminator
nims11's Avatar
Default a simple OOP doubt
please clear my doubt
if a class A inherits from B, then why would the private members of the base class B will contribute to the size of the object of derived class A?
P.S.- C.Sc board exam on 30th!!
nims11 is online now   Reply With Quote
Old 25-03-2011, 07:19 PM   #2 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Default Re: a simple OOP doubt
It's because the private members do exist in the memory, and are actually there with the class and they are only inaccessible to the derived class members and objects. The public base methods which are inherited WILL be able to access, modify the base members.
It could very well be that you are modifying the private members through the public methods of the class. For instance:
class B    {
   private:
       int var;
   public:
       void modify_var(int v)    {
           var = v;
class A : public B   {
   private:
        int num;
   public:
       void modify_A_var(int v, int n) {
           modify_var(v);
           num = n;
You can see in modify_A_var() in class A is accessing a private member of class A only albeit through a member function of the base class.
P.S.: My C++ is rusty, not programmed for over a year, feel free to correct if my post is wrong or has errors.
P.P.S.: Best of luck for the exam
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline   Reply With Quote
Old 25-03-2011, 09:11 PM   #3 (permalink)
pulkitpopli2004's Avatar
yeah hez right
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
pulkitpopli2004 is online now   Reply With Quote
Old 25-03-2011, 09:25 PM   #4 (permalink)
BIOS Terminator
nims11's Avatar
Thanx a lot LFC_fan.
i played with the code and now everything is clear!! my appreciation for OOP has increased after understanding this...
