I have an ms access file which has around 15 queries and a few tables. It was created by someone else and now i am to take care of it. Now i am having problem relating all the queries and getting the flow. Is there a way where in u can maybe get a diagrammatic representation of the queries and the relationships, dependencies etc in access ? or is there a better way.. pls suggest
You should be able to open each query and see the dependent tables and queries. Also you can select each object and view the dependencies from VIEW.
