Old 19-03-2011, 04:33 PM   #1 (permalink)
Default Regular expressions in python
hello everybody, I want to create a regular expression (in Python) for which I select all the string in between
/* and */ including all spaces, tabs, newline etc.
for example,
/* HELLO */
/* HELLO
EVERYONE */
these should be selected with and without \n. I have trying for 2 hrs and still trying. I was able to achieve without newline character, i.e. I can get string /* HELLO */ but not
/* HELLO
EVERYONE */
I did the following
/\*(\w+\s*+\n*)+\*/
/\*[\w+\s*+\n*]+\*/
any many other do not remember all that.
Please write that regular expression for me!!
abhijangda is online now   Reply With Quote
Old 20-03-2011, 10:14 AM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: Regular expressions in python
i dont work on python but in C#, the entire text can be represented as a string with escape sequence
/t = tab
/n = new line
the string would look something like ::
/* HELLO/nEVERYONE */
and that works for the regex
arpanmukherjee1 is offline   Reply With Quote
Old 27-03-2011, 08:29 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Smile Re: Regular expressions in python
Originally Posted by abhijangda View Post
I did the following
/\*(\w+\s*+\n*)+\*/
/\*[\w+\s*+\n*]+\*/
It is a simple matter of iterating over issues and building your solution.
Starting off, you will want to match 'any' string, not characters belonging to a set (A simple .* within comments, perhaps). Next, you'll need to handle detection of newline characters (\r as well as \n, if you may).
Then you'll need to understand that regex is greedy, since it would now be matching against multiple comments spread in a document (A /**//**/ would be matched as a single one). Once you've figured out a way to avoid THAT, you'll need to find a way to support comments that have multiple '*'s in them, a common sight for multi-line comments from IDEs/code-editors.
By now it would be a complex regex that STILL would not do it all for you (multiple ending *s in a line? boom!). But anyways, what are you gonna use it for?
We could write it down for you, but that'd defeat the purpose of this board wouldn't it? But well, you can always search the web - your problem isn't unique.
Harsh J
www.harshj.com
QwertyManiac is offline   Reply With Quote
