A rather simple program that represents working of a queue
/* Queue */
#include<stdio.h>
#define MAX 10
typedef struct{
int q[MAX];
int front,rear;
}queue;
int main(){
int flushqueue(queue *,int);
int isfull();
int isempty();
int enqueue(queue *,int);
int dequeue(queue *);
int printqueue(queue);
queue que;
que.front=que.rear=-1;
int a,choice,item;
a=flushqueue(&que,-1);
while(choice!=4){
printf("\n\n\n\t*** Queue ***\n");
printf("1. Enqueue\n2. Dequeue\n3. Display queue\n4. Exit");
printf("\nEnter choice : ");
scanf("%d",&choice);
switch(choice){
case 1:
if(isfull(que))
printf("Queue Full!");
else{
printf("Enter number to be added : ");
scanf("%d",&item);
a=enqueue(&que,item);
if(a==0){
printf("Number added sucessfully!\n");
a=printqueue(que);
break;
case 2:
if(isempty(que))
printf("Queue Empty!");
else{
printf("%d deleted sucessfully!",dequeue(&que));
printqueue(que);
break;
case 3:
a=printqueue(que);
break;
return 0;
int isfull(queue que){
if(que.front==0 && que.rear==MAX-1)
return 1;
else
return 0;
int isempty(queue que){
if(que.front==-1)
return 1;
else
return 0;
int enqueue(queue *que,int v){
int i,a;
if(que->front==-1)
que->front=que->rear=0;
else if(que->rear=MAX-1){
for(i=que->front;i<que->rear;i++){
que->q[i-que->front]=que->q[i];
a=flushqueue(&que,i);
que->rear=que->rear-que->front+1;
que->front=0;
else
que->rear++;
que->q[que->rear]=v;
return 0;
int dequeue(queue *que){
int t,a;
t=que->q[que->front];
a=flushqueue(que->front);
if(que->front==que->rear)
que->front=que->rear=-1;
else
que->front++;
return t;
int printqueue(queue que){
int i;
for(i=0;i<MAX;i++)
printf("%d ",que.q[i]);
return 0;
int flushqueue(queue *que,int s){
int i;
if(s==-1){
for(i=0;i<MAX;i++)
que->q[i]=0;
else
que->q[s]=0;
return 0;
But when I compile and run the code, I get an error while adding an entry the second time. Terminal output below:
[srvmdk@localhost Rough]$ gcc Queue.c
[srvmdk@localhost Rough]$ ./a.out
*** Queue ***
1. Enqueue
2. Dequeue
3. Display queue
4. Exit
Enter choice : 1
Enter number to be added : 10
10 0 0 0 0 0 0 0 0 0
*** Queue ***
1. Enqueue
2. Dequeue
3. Display queue
4. Exit
Enter choice : 1
Enter number to be added : 12
Segmentation fault (core dumped)
Any ideas why and any solution how to avoid it? Thanks in advance.
