@OP: you mean to say you need to create a pdf file on yourself with your own text. then just type or the text in openoffice.org and use the option "export as pdf" present in the standard toolbar.
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
^^ Thank you. I have created that program. Now I want to try a .html/.mht file.
Actually I wanted to ask that if I don't know the contents of the file, what parameters do I set so that it converts the specified thing into pdf page.
---------- Post added at 02:46 PM ---------- Previous post was at 02:42 PM ----------
For this I think an HTML library might also be required.
