Old 09-01-2011, 06:12 PM   #1 (permalink)
sganesh's Avatar
Default How to sort html table values using select box
hi ,
In below code,How to sort html table column values based values selected in select box.
The html content s
<html>
<body>
Sort by<select>
<option>Name</option>
<option>Surename</option>
<option>Age</option>
</select>
<table border="1" class="" width="400">
<thead>
<tr>
<th>Name</th>
<th>Surename</th>
<th>Age</th>
</tr>
</thead>
<tbody>
<tr >
<td >John1</th>
<td >Smith1</th>
<td >30</th>
</tr>
<tr >
<td >John2</th>
<td >Smith2</th>
<td >31</th>
</tr>
<tr >
<td >John3</th>
<td >Smith3</th>
<td >32</th>
</tr>
<tr >
<td >John4</th>
<td >Smith4</th>
<td >33</th>
</tr>
<tr >
<td >John5</th>
<td >Smith5</th>
<td >34</th>
</tr>
<tr >
<td >John</th>
<td >Smith</th>
<td >35</th>
</tr>
<tr >
<td >John</th>
<td >Smith</th>
<td >36</th>
</tr>
<tr >
<td >John</th>
<td >Smith</th>
<td >37</th>
</tr>
</tbody>
</table>
</body>
</html>
Is the problem can be solved in javascript?
sganesh is offline   Reply With Quote
Old 09-01-2011, 06:44 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: How to sort html table values using select box
the answer to ur ques is -- yes.
but first i'd like to give some tips
1. please indent ur code. specially HTML. makes it lot more readable
2. if it was indented always use
this is CODE tag
3. please google up the topic before posting it here.
4. if u did look it up. give reference and tell why it didnt solve ur issue
now for ur answer:
Javascript table sorting script
JavaScript Toolbox - Sortable Table
if u want to sort only through the dropdown. extract the function from the script and use it on button click that would be just adjacent to the dropdown
arpanmukherjee1 is offline   Reply With Quote
Old 09-01-2011, 08:23 PM   #3 (permalink)
sganesh's Avatar
thanks for the info
i ve used sortable js found in
Sortable Table (WebFX)
the code s as follows,But didnt work.
Could someone help me in fixing this issue.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<script type="text/javascript" src="js/sortabletable.js"></script>
<script type="text/javascript">
var st2 = new SortableTable(document.getElementById("table-2"),
["String", "String", "Number"]);
function alertselected(selectobj){
if(selectobj.selectedIndex.valueOf()=="1")
alert(st2.sort(0))
if(selectobj.selectedIndex.valueOf()=="2")
st2.sort(1)
if(selectobj.selectedIndex.valueOf()=="3")
st2.sort(2)
</script>
</head>
<body>
<form id="someform">
<select id="mymenu" size="1" onChange="alertselected(this)">
<option value="nothing" selected="selected">Select a Sort</option>
</select>
</form>
<table class="sort-table" cellspacing="1" cellpadding="2" border="1" id="table-2" width="400">
<thead>
<tr>
<th>Name</th>
<th>Surename</th>
<th>Age</th>
</tr>
</thead>
<tbody>
<tr >
<td >John1</th>
<td >Smith1</th>
<td >30</th>
</tr>
<tr >
<td >John2</th>
<td >Smith2</th>
<td >31</th>
</tr>
<tr >
<td >John3</th>
<td >Smith3</th>
<td >32</th>
</tr>
<tr >
<td >John4</th>
<td >Smith4</th>
<td >45</th>
</tr>
<tr >
<td >John5</th>
<td >Smith5</th>
<td >34</th>
</tr>
<tr >
<td >John</th>
<td >Smith</th>
<td >35</th>
</tr>
<tr >
<td >John</th>
<td >Smith</th>
<td >36</th>
</tr>
<tr >
<td >John</th>
<td >Smith</th>
<td >37</th>
</tr>
</tbody>
</table>
</body>
</html>
