i hav been tryin to place a password for my mysql database,bt i awlways gets this error
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that
corresponds to your MySQL server version for the right syntax to use near 'use mysql
the code is:
mysql> use mysql
Database changed
mysql> UPDATE user
-> SET Password=PASSWORD<'nanana'>
-> WHERE user='root' ;
can any one tell whts wrong???
