Old 30-11-2010, 07:09 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default 8086 programming problem
In 8086 CPU the following register contents are
CS:4100H DS:A000H BX:0350H IP:0100H
The 8086 fetches the following instruction using above register
MOV [BX] , AX
1) Which is the memory address from where the instruction is fetched?
2)Which is the memory address where the data that is in AX is stored?
gaurav9991 is offline   Reply With Quote
Old 30-11-2010, 09:13 PM   #2 (permalink)
pulkitpopli2004's Avatar
Default Re: 8086 programming problem
as far as i remember
1. instruction will be fetched from the address present in instruction pointer IP i.e eq to 0100H
2. And AX will be stored at address 0350H
pulkitpopli2004 is offline   Reply With Quote
Old 01-12-2010, 07:58 AM   #3 (permalink)
i am agree with you for the first answer but for second indirect addressing mode is used. Had it been MOV A,B then it would be 035H
am i correct ?
Old 02-12-2010, 01:39 AM   #4 (permalink)
well [BX] tells that the the value of the AX will be stored not in BX bt at the address of BX..
and address of BX is 0350H.. so i think this wud b d only solution
Old 19-12-2010, 10:51 AM   #5 (permalink)
MOV [BX] , AX
I believe that the instructions are fetched from 4200H and the data is stored in A350H.
silent008 is offline   Reply With Quote
Old 06-01-2011, 10:53 PM   #6 (permalink)
I think it is 4200 high order address.
Jerin is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/programming/134555-8086-programming-problem.html
8086 instruction question This thread Pingback 01-12-2010 12:01 AM
