Old 05-11-2010, 01:12 PM   #1 (permalink)
yomanabhi's Avatar
Default Is there is way to revolve images.
I want to make for my site something that:
images will revolve automatically, but if we place mouse pointer over it in middle it will stop revolving, but if will place at right, images will start revolving at right, but if will place at left, images will start revolving at right. Each images give hyperlink to a page.
I saw this on many site, but can't find way to make it. Plz Help me
plz help guys
If U mess with me, U will be HACKED!!
Get all Hacking Tips & Tricks, on www.gen-xtechcentre.webs.com
yomanabhi is offline
Old 07-11-2010, 11:13 PM   #2 (permalink)
Default Re: Is there is way to revolve images.
i think you can do it with image maps + javascript
http://img694.imageshack.us/img694/7417/tempmp.jpg
How am I supposed to meet my freetard friends and talk about Linsux now?
lucifer_is_back is offline
Old 08-11-2010, 02:47 PM   #3 (permalink)
BIOS Terminator
nims11's Avatar
you can give the revolving effect by simultaneously moving the images horizontally and zooming in/out at the same time using javascript.
maybe it will be easier in flash
nims11 is offline
Old 09-11-2010, 05:20 PM   #4 (permalink)
yomanabhi's Avatar
Hey don't tell me in which it can done.
Give me its whole coding and tutorial
Thanx..
Old 09-11-2010, 05:40 PM   #5 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
In any forum or site no one will spoon feed you. nims11 just suggested you possible ways to do it. We expect you to search a little bit and find your desired script.
Here I found one script, please see if it helps you:
JavaScript Image Rotator - Timed Image Swap
Here is instruction set:
http://www.dyn-web.com/code/rotate_i...umentation.php
And the download link:
http://www.dyn-web.com/zipped/dw_rotate.zip
Found this one also:
http://raphaeljs.com/image-rotation.html
Kinda funny
My personal blog - http://gagan.scholarguru.com
gagan007 is offline
Old 10-11-2010, 02:08 PM   #6 (permalink)
Thanx..
worse than script kiddie
