A form in a html page (contact.htm) submits the data to asp script
<form name="test" method="post" action="cdosys.asp">
This code was downloaded from Internet.
I want to implement google lab's recaptcha on my form. I place the following code (as on their website) at the top of the page as rename my file as contact.asp
recaptcha_challenge_field = Request("recaptcha_challenge_field")
recaptcha_response_field = Request("recaptcha_response_field")
recaptcha_public_key = "6LeYdL0SAAAAAJsYBKQI334EKlophwjQH8MXcma_" ' your public key
recaptcha_private_key = "6LeYdL0SAAAAAN8wYCezXdQeFodbYbw80dzVJxYs" ' your private key
' returns the HTML for the widget
function recaptcha_challenge_writer()
recaptcha_challenge_writer = _
"<script type=""text/javascript"">" & _
"var RecaptchaOptions = {" & _
" theme : 'clean'," & _
" tabindex : 0" & _
"};" & _
"</script>" & _
"<script type=""text/javascript"" src=""http://www.google.com/recaptcha/api/challenge?k=" & recaptcha_public_key & """></script>" & _
"<noscript>" & _
"<iframe src=""http://www.google.com/recaptcha/api/noscript?k=" & recaptcha_public_key & """ frameborder=""1""></iframe><>" & _
"<textarea name=""recaptcha_challenge_field"" rows=""3"" cols=""40""></textarea>" & _
"<input type=""hidden"" name=""recaptcha_response_field""value=""manual_challenge"">" & _
"</noscript>"
end function
' returns "" if correct, otherwise it returns the error response
function recaptcha_confirm(rechallenge,reresponse)
Dim VarString
VarString = _
"privatekey=" & recaptcha_private_key & _
"&remoteip=" & Request.ServerVariables("REMOTE_ADDR") & _
"&challenge=" & rechallenge & _
"&response=" & reresponse
Dim objXmlHttp
Set objXmlHttp = Server.CreateObject("Msxml2.ServerXMLHTTP")
objXmlHttp.open "POST", "http://www.google.com/recaptcha/api/verify", False
objXmlHttp.setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
objXmlHttp.send VarString
Dim ResponseString
ResponseString = split(objXmlHttp.responseText, vblf)
Set objXmlHttp = Nothing
if ResponseString(0) = "true" then
'They answered correctly
recaptcha_confirm = ""
else
'They answered incorrectly
recaptcha_confirm = ResponseString(1)
end if
end function
server_response = ""
newCaptcha = True
if (recaptcha_challenge_field <> "" or recaptcha_response_field <> "") then
server_response = recaptcha_confirm(recaptcha_challenge_field, recaptcha_response_field)
newCaptcha = False
end if
As you can see the form sends contents to cdosys.asp when submitted. I don't get how to implement recatcha here.
Any ideas??
Source:
Using reCAPTCHA with Classic ASP - reCAPTCHA - Google Code
