Old 18-09-2010, 03:29 PM   #1 (permalink)
rohanz's Avatar
Smile Help to choose programming language for a 9th standard student
hey guyz I am Rohan and I am in 9th standard plz help me choose a language to start programming I want to develop games ,apps , softwares and oses plz help me i know only html now
here are sme recommendations
  • python
  • php
  • java
  • c#
  • c++
  • visual basic
  • dhtml
  • xml
  • xhtml
  • sql
  • 3D
http://techieforums.net
my forum plz pay a visit
rohanz is offline   Reply With Quote
Old 18-09-2010, 05:53 PM   #2 (permalink)
BE FREE
Default Re: plz help me guyz..
If you are serious of gaming career and you are good numbers and logic, then pick only C++ and master it thoroughly.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline   Reply With Quote
Old 27-11-2010, 03:45 PM   #3 (permalink)
Coder Kingkong
Default Re: Help to choose programming language for a 9th standard student
1)Learn the basics properly: Get your OOP (Object oriented Programming )concepts right.
2) Practice: Practicing what you learn is most important and one cannot achieve goal of being a good programmer without practicing.
3) Learn to share : Sharing is the most important aspect of programmers.
5)Must learn: XML, HTML, JavaScript or any other scripting language, Ajax, SQL. This are the few basic things.
6)Track: After learning Basics and terminologies , choose just one platform. Programming languages are in vast numbers, Java, c#, C++, perl, PHP, ruby etc.
For more details you can check my Blog.
Any help you want regarding which books to refer, which are the good institutes to start out, ask me
sanketJ is offline   Reply With Quote
Old 27-11-2010, 07:27 PM   #4 (permalink)
abhidev's Avatar
I would suggest u start with the basic...thats c which will help you develop logic...then u can later pickup c++ and so on.
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 27-11-2010, 08:46 PM   #5 (permalink)
web
Smile Re: Help to choose programming language for a 9th standard student
Hello Rohan,
As you are still in 9th standard, learn the basics of which you find easy. You have a long way to master them
BTW as you said you know HTML, it would be easy for you to learn XHTML and PHP
web is offline   Reply With Quote
Old 28-11-2010, 06:05 PM   #6 (permalink)
a_k_s_h_a_y's Avatar
game programming ?!! LOL ok
C, C++, C#! Game engines, go get them!
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is online now   Reply With Quote
Old 29-11-2010, 11:31 AM   #7 (permalink)
Point Blanc
hmm, ok
start with c or java for programming language. c or java will give you good platform for furthur areas or concepts to learn. more than c I will say check java because then you will be able to understand object oriented concepts.
you know a scripting language as HTML, so you can learn XML, XHTML or PHP as web said, do not go into javascript that quick as it does not have a fixed set of rules. it majorly depends upon browser what javascript calls will run
acewin is offline   Reply With Quote
Old 29-11-2010, 12:29 PM   #8 (permalink)
abhidev's Avatar
First of all...what are you interested in...software dev or web dev...if u wanna go for software dev then i would suggest go for c,c++,java,.net but if u r interested in web dev then go for javascript, php,etc...but keep in mind that languages like java and .net can are also used in web. So decide for yourself. All the best
Old 29-11-2010, 05:31 PM   #9 (permalink)
damnthenet's Avatar
It's quite easy to create small games (like flash games) for web or mobile using Silverlight. This is a technology and not a language.
I would suggest you to learn the basic OOP concepts and then learn C# which is a good language for OOP development. Using this language and .NET framework, you can create wonderful applications including games for the web and the mobile.
Sony Xperia Neo V - Review and Discussion Thread:
http://www.thinkdigit.com/forum/mobi...ml#post1520514
damnthenet is offline   Reply With Quote
Old 03-02-2011, 04:07 PM   #10 (permalink)
Go for an Object oriented Language..... that will surely help!!
To start nothn can be better than C++.
tasamono is offline   Reply With Quote
Old 03-02-2011, 06:47 PM   #11 (permalink)
Nemes!s's Avatar
Go for C#... it will be easy for you to learn basic programming concepts and u can create kool games in c# as well. As u advance then you can go for c++
Athlon II X4 635 @ 2.9Ghz || Biostar TA785G3 HD || G.skill 2X2Gb 1333Mhz DDR3 || WDC 500Gb Green || Corsair VX550W || CM Elite 330 || BenQ 2220HD || HTC Inspire 4G :))
Nemes!s is offline   Reply With Quote
Old 04-02-2011, 10:17 PM   #12 (permalink)
Start with Visual Basic first. Learn it thoroughly. This will help you get your functional and modular programming concepts stronger. Then go to Python. Master it with Object Oriented Programming approach. Go to C/C++ only if you want to go in field of system programming. Programming is not that much easy. If you want to be a game developer go for C++ and Java and master it. But I would say master VB and Python first. Python is a very good and easy language with large library. You can make anything in Python much easily. Also Python is cross-platform but VB is only for Windows. VB too is very good. Go for these two.
abhijangda is offline   Reply With Quote
Old 07-02-2011, 06:59 PM   #13 (permalink)
BIOS Terminator
nims11's Avatar
Go for C or C++, install it completely in your brain by thorough practice. There are several websites to serve this purpose.
after this, you can either go for advanced areas of C/C++ or choose any other language
nims11 is offline   Reply With Quote
Plz Help to buy a New PC manoprabhu77 PC Components / Configurations 35 01-03-2011 09:36 PM
plz help me buy a camera rohanz Cameras and camcorders 17 25-01-2011 01:09 PM
plz hlp... urgent..!!! rohanz Hardware Q&A 1 01-09-2010 06:02 PM
bsnl uploading query plz help stevebadshah Broadband and DTH 1 23-05-2010 07:55 PM
