Old 16-08-2010, 04:17 PM   #1 (permalink)
Smile Asp.Net
I am looking right click menu (Context Menu) with icons on HTML page. That I want to populate from a external xml file.
And I am using the technology is ASP.Net (C#).
Can anyone give some examples....
jijimathew is offline   Reply With Quote
Old 16-08-2010, 10:31 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: Asp.Net
where do u want to place the context menu ?
is it associated with control ?
have a look at Cutting Edge: Adding a Context Menu to ASP.NET Controls
associate a image. in the XML file save the filename of the img and send it to javascript. the control will then be able to bind the img and the text.
arpanmukherjee1 is offline   Reply With Quote
Old 22-01-2011, 09:57 AM   #3 (permalink)
Default Re: Asp.Net
Asp.Net is really is open source and good language for the programming.It is used visual studio software for the programming.Sql server is available inbuilt in this software.Designing and coding is so easy to learn in this software.
___________________
Modular Buildings
rikymartine2011 is offline   Reply With Quote
Old 23-01-2011, 11:02 AM   #4 (permalink)
Nemes!s's Avatar
Default Re: Asp.Net
this can be done with javascript.. just google it u will find many example
Athlon II X4 635 @ 2.9Ghz || Biostar TA785G3 HD || G.skill 2X2Gb 1333Mhz DDR3 || WDC 500Gb Green || Corsair VX550W || CM Elite 330 || BenQ 2220HD || HTC Inspire 4G :))
Nemes!s is offline   Reply With Quote
ASP.net problems arpanmukherjee1 Programming 0 24-07-2010 12:47 AM
User profiling in ASP.net .. if its called so! deepakgates Programming 13 04-05-2010 11:50 PM
asp.net 3 tier architecture help meghraj Programming 1 03-05-2010 12:34 AM
asp.net sqlparameter error meghraj Programming 1 20-03-2010 07:59 PM
asp.net database.cs help meghraj Programming 3 09-03-2010 06:15 PM
