Old 24-07-2010, 12:47 AM   #1 (permalink)
XLr8
arpanmukherjee1's Avatar
Default ASP.net problems
i am relatively new to ASP but well educated on C# & C
i have multiples problems.
1. i want to develop asp page like the codepad. now limiting to compiling only C codes. i choose tiny c compiler . it says it can take program inputs from standard input but on win xp it says "declaration missing"
2. how to save a text in the textbox and save it in a file and run it consecutively. giving commands is very easy . See :How to Execute a Command in C# ? - CodeProject
3. how to display color highlighting syntax in textbox ??
pl. try to answer from purely academic point of view. try to give links to solutions that u think r the most appropriate.
give any other alternative command line c compiler
arpanmukherjee1 is offline   Reply With Quote
Host of Problems Soumyajit Hardware Q&A 3 26-06-2010 06:17 PM
User profiling in ASP.net .. if its called so! deepakgates Programming 13 04-05-2010 11:50 PM
asp.net 3 tier architecture help meghraj Programming 1 03-05-2010 12:34 AM
:::::earthing problems:::::: ::cyborg:: Hardware Q&A 8 29-04-2010 02:50 PM
asp.net database.cs help meghraj Programming 3 09-03-2010 06:15 PM
