Old 14-07-2010, 11:44 AM   #1 (permalink)
siddharthmakwana's Avatar
Default problem: Front end in C# and backend in C?
Is it possible to connect front end created in C#(visual studio) to a C file as a back end...?
i want to make a MD5 sum calculator for which i have prepared GUI in C# and i do have a C code that generates MD5 sum of a given file or text. the C code takes the file path or string as a command line arguments.....
GUI consist of two text boxes. one to input filename or text and other in which MD5 sum should be printed...
Ubuntu Natty Narwhal | RHEL 6 | Win XP
Windows is Past... Future is Open..!!
siddharthmakwana is offline   Reply With Quote
Old 14-07-2010, 07:44 PM   #2 (permalink)
Default Re: problem: Front end in C# and backend in C?
yes
create the C code as a DLL project and use it in C# project
google on how to use C dll in c#
http://img694.imageshack.us/img694/7417/tempmp.jpg
How am I supposed to meet my freetard friends and talk about Linsux now?
lucifer_is_back is offline   Reply With Quote
Old 14-07-2010, 07:55 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
Or you can "execute a command" (your C program executable) passing the parameter and return the string which can be displayed in the text box.
Though I recommend to write the program in C# instead of using it as a command.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
Old 14-07-2010, 11:23 PM   #4 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Any reasons ? I've always assumed that code is much faster when executed in C compared to modern high level languages...
And for a digest algorithm this should be a human noticable time difference for larger files right ?
Apple iPad 2 16GB WiFi
MetalheadGautham is offline   Reply With Quote
Old 14-07-2010, 11:41 PM   #5 (permalink)
God of Mistakes...
Garbage's Avatar
That recommendation isn't because of the execution speed. But invoking (OS) commands from program is never considered as good option.
And BTW, read the following links please. Just for information.
Canned Platypus Blog Archive It’s Faster Because It’s C
Hacker News | It?s Faster Because It?s C
Old 15-07-2010, 03:13 AM   #6 (permalink)
it is always speed vs effort
in this case if he implements both UI n BL in C# , he will effort with no penalty in speed
Old 16-07-2010, 02:00 PM   #7 (permalink)
XLr8
arpanmukherjee1's Avatar
i developed a form applic in C# for finding duplicate files using md5 Hash.
used the md5 security class
it worked out quiet nicely for large files also.
for files of 3 - 10 GB used file splitting method. will post src code if you like.
---------- Post added at 02:00 PM ---------- Previous post was at 01:57 PM ----------
[QUOTE=lucifer_is_back;1262221
[/QUOTE]
this is what i think is the best method for using c codes in other langs.
arpanmukherjee1 is offline   Reply With Quote
Old 18-07-2010, 11:00 AM   #8 (permalink)
God of Mistakes...
Garbage's Avatar
Great... Host the project on Sourceforge or Github or GoogleCode or CodePlex and please provide a link.
And BTW, under which license are you publishing your code? I'm just curious...
Old 18-07-2010, 06:38 PM   #9 (permalink)
XLr8
i did not create any class of my own, just used it.
i did it for request of friend of mine (avid collector of hindi songs) who was having same mp3 file multiple times over the drive.
i did not publish it anywhere, i will upload it to RS with src,(tomorrow)
change as u like
but tell me if u do smthing interesting with it
Old 19-07-2010, 12:57 AM   #10 (permalink)
Thumbs up Re: problem: Front end in C# and backend in C?
i think CRC32 is enough for this purpose.....
Old 19-07-2010, 02:49 PM   #11 (permalink)
God of Mistakes...
Garbage's Avatar
change as u like
I will still insist to host the project on some site. It will be helpful for others as well as you for issue tracking and improvement.
Old 27-07-2010, 10:17 AM   #12 (permalink)
XLr8
now here is my code :: RS :: report if links broken
Setup::
RapidShare: 1-CLICK Web hosting - Easy Filehosting
MD5: 2B439A7732BE0B5E61BED21EBB033FDD
solution::
MD5: 462A1D05BCBEB912F9319674D5E28561
Old 28-07-2010, 09:37 AM   #13 (permalink)
XLr8
anybody dwnloaded it yet
Old 28-07-2010, 08:35 PM   #14 (permalink)
God of Mistakes...
Garbage's Avatar
Will download and try tonight. Have to boot into Windows. :S
Old 29-07-2010, 09:38 AM   #15 (permalink)
downloaded it
trying out
---------- Post added at 09:38 AM ---------- Previous post was at 09:31 AM ----------
got the following error on rebuilding the solution
Error 1 Unable to find manifest signing certificate in the certificate store. FileSpider
Old 29-07-2010, 07:38 PM   #16 (permalink)
XLr8
my bad... sorry ::: delete all files from ./Filespider/bin & Debug folder
if that dont work consult
Unable to find manifest signing certificate in the certificate store. (MSB3323) - SharpDevelop Community
& this
error MSB3323: Unable to find manifest signing certificate in the certificate store.
Old 30-07-2010, 09:06 PM   #17 (permalink)
changed the solution settings
