Old 06-07-2010, 01:53 PM   #1 (permalink)
rajwansh2003's Avatar
Default SQL 2005 error
I am using:
Windows 7, sql server 2005
my problem is that i can not connect from data base......
Anupam
rajwansh2003 is offline   Reply With Quote
Old 06-07-2010, 02:20 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: SQL 2005 error
plz be more specific
post coding, what server r u using
arpanmukherjee1 is offline   Reply With Quote
Old 06-07-2010, 07:43 PM   #3 (permalink)
My error
http://img267.imageshack.us/img267/7100/89597018.jpg
Anupam
Old 07-07-2010, 11:41 AM   #4 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
I received this error a while ago...I forgot what exactly did I do to resolve that but all I can think now is....
check if services related to SQL Server are running under services.msc console (specially by name SQL Server Agent (MSSQLSERVER) and SQL Server (MSSQLSERVER)).
I am sure that they are not running...
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 07-07-2010, 02:45 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Go to the SQL Server Configuration Manager, Microsoft SQL Server 2005>>Configuration tools>>SQL Server Configuration Manager, and start the SQLEXPRESS service. Just put it to automatic.
asingh is offline   Reply With Quote
Old 07-07-2010, 07:09 PM   #6 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Are you trying to connect to a remote SQL instance? you should enable it first, then.
Open the surface area configuration tool, and in the remote connections tab, allow remote connections using both tcp and named pipes.
dheeraj_kumar is offline   Reply With Quote
Old 08-07-2010, 11:10 AM   #7 (permalink)
gagan007's Avatar
It is on his local computer dude.
Old 09-07-2010, 04:44 PM   #8 (permalink)
mayanksharma's Avatar
check your SQL server Instance Name under service manager.
enable sql server service from services.msc!
mayanksharma is offline   Reply With Quote
Old 28-07-2010, 08:02 AM   #9 (permalink)
I still got the problem and and finally installed SQL Server 2008- working fine and smooth....
Anupam
I/O error while copying some data on to external HDD gary4gar Open Source 4 02-11-2007 12:31 PM
World’s Largest Windows Error Message iMav Random News 46 01-04-2007 07:08 PM
GNU/Liberty Basic Compiler installation error ! eagle_y2j Open Source 6 13-03-2007 01:18 PM
New Problem !!! saROMan QnA (read only) 3 28-06-2005 08:18 PM
ERROR OPENING VCD [HEEELP....] vijaythefool QnA (read only) 8 19-04-2005 12:07 PM
