Old 01-07-2010, 01:14 AM   #1 (permalink)
Default Summation of Columns in SQL
Suppose I have 3 columns of 3 different subjects say History, Maths and Science. Now I want to add the total of their values to another column say Total. Is it possible in MySQL? Is there any function for doing this. Also MySQL should automatically update the values when its data is stored in 3 columns of 3 different subjects. For e.g., Somebody has entered History Marks and another has entered Maths Marks. Then MySQL should automatically calculate the sum of History and Maths and keep the total even though the value of Science has not been entered. How this can be done with PHP and MySQL? Please Help
Join My Mailing List at
http://groups.google.co.in/group/cooldev007smail
cooldev007 is offline   Reply With Quote
Old 01-07-2010, 10:10 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Summation of Columns in SQL
i dont abt MySQL but in SQL u can create a trigger for the requirement u have....
Old 01-07-2010, 11:11 AM   #3 (permalink)
Excessive happiness
furious_gamer's Avatar
@OP
Nope, MySQL doesn't do this. You have to write a trigger or a Stored Procedure to achieve this.
Just learn trigger and SP and this task is very easy as it sounds, trust me.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline   Reply With Quote
Old 01-07-2010, 11:50 AM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
IMO, View is the ideal for this. Because it won't store total actually, but will calculate it when needed.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
Old 01-07-2010, 12:39 PM   #5 (permalink)
Excessive happiness
Can you elaborate this? I dont get you.
PS Request
Old 01-07-2010, 02:04 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
i got the solution:
just use default constraint on the table.....
no need of SP & trigger @ all
Old 07-07-2010, 07:48 PM   #7 (permalink)
Thank To you all for your posts... How Can I Do this in Access 2007? Kindly Reply
Help! Sql: copy values from one field to another in the same table phuchungbhutia Programming 1 19-03-2010 09:50 AM
Problem installing SQL Server 2000 coolazeem Software Q&A 4 10-02-2006 08:22 PM
distributing application developed using vb and sql server rajesh_nk22 QnA (read only) 1 07-02-2006 05:04 PM
PHP ODBC Connection failed , Sql Server 2000, help Butterfly QnA (read only) 5 03-10-2004 09:55 PM
