Old 12-06-2010, 11:47 AM   #1 (permalink)
Lightbulb core java issue:alternative for super keyword in static method
as you know java doesn't allow the use of super keyword inside a static method,is their any way to access the data member of super class having same name and type as that of a local data member in main method without creating an object reference.
class A
static int x=10;//access to 10 without object reference
class B extends A
public static void main(String []rc)
int x=11;
System.out.println("--"+x);//prints 11
rahulchand is offline   Reply With Quote
Old 12-06-2010, 03:41 PM   #2 (permalink)
prttal's Avatar
Default Re: core java issue:alternative for super keyword in static method
You may create another non-static function like
public int getVal()
//code here
prttal is offline   Reply With Quote
Old 17-06-2010, 07:06 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
Can't you do like
System.out.println("--"+A.x);
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline   Reply With Quote
decide between intel core2 duo or phenom amd quad core Dr Mohit Hardware Q&A 3 28-05-2010 06:57 PM
Running swf files from Java channabasanna Programming 0 03-03-2010 05:53 PM
[suggest] cheap dual sim java phone phuchungbhutia Buying Advice 2 12-02-2010 05:14 PM
Valuable Sites for Techies sreedevi Tutorials 15 04-10-2005 10:35 PM
Intel Pentium D 2.80 Ghz reviewed (dual core) mohit CPU / Motherboards 1 27-05-2005 02:11 PM
