Old 08-06-2010, 02:29 PM   #1 (permalink)
Question vb.net or C# to enable/disable LAN
Hi all
im having dataone 500 plan.So to automate the night download have written code in vb.net to restart modem, enable/disable the network connection, start/stop softwares etc..It was done for the windows XP machine and worked fine for last 1 year..Now i installed windows 7 but not able to access the network connections from vb.net..Can some one help me out? Vb.net or C# code please
Thanx and regards
CsK
mr.csk is offline   Reply With Quote
Old 08-06-2010, 11:54 PM   #2 (permalink)
Default Re: vb.net or C# to enable/disable LAN
can u post ur program code?? may be some changes are required. also in which edition of vb.net you wrote this code. i mean in vb.net 2005 or 2008 or in any other edition??
abhijangda is offline   Reply With Quote
Old 09-06-2010, 12:43 AM   #3 (permalink)
Super Moderator
asingh's Avatar
You must be calling some API, that could have changed. Check it out again.
asingh is offline   Reply With Quote
Old 20-06-2010, 08:58 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Run it as administrator.
dheeraj_kumar is offline   Reply With Quote
Old 20-06-2010, 09:37 PM   #5 (permalink)
Always confused
vamsi360's Avatar
Smile Re: vb.net or C# to enable/disable LAN
+1
Run it as admin
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline   Reply With Quote
Getin Admin Access in LAn Ron Software Q&A 8 24-04-2010 10:03 PM
Sending image from VB.net to Matlab and vice versa furia_bhavesh Programming 0 12-04-2010 11:51 AM
LAN port not working suniltr77 Hardware Q&A 2 25-01-2010 08:08 PM
Requirements for Setting Up A Home Network caje143 Software Q&A 2 05-04-2007 04:52 AM
