Old 19-05-2010, 06:54 PM   #1 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Panel Control in C#
hello,
i have a panel.
i add label and a pictureBox using this :
private void AddLabelAndImage(ref Point startPoint, string labelText, System.Drawing.Image image)
            Label label = new Label();
            panel1.Controls.Add(label);
            label.Text = labelText;
            label.Name = "text";
            label.Width = 100;
            label.Height = 30;
            label.Location = startPoint;
            startPoint.Y += label.Height;
            System.Windows.Forms.PictureBox box = new PictureBox();
            panel1.Controls.Add(box);
            box.Name = "image";
            box.Size = image.Size;
            box.Image = image;
            box.Location = startPoint;
            startPoint.Y += box.Height + 10;
what i want is to retrieve the picturebox control as System.Windows.Forms.PictureBox.
every function like find() returns Control[]
how to do this??
arpanmukherjee1 is offline   Reply With Quote
Old 27-05-2010, 02:27 PM   #2 (permalink)
Always confused
vamsi360's Avatar
Default Re: Panel Control in C#
you have to returen the reference of the control i guess. I will try and tell you...
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline   Reply With Quote
Old 27-05-2010, 10:32 PM   #3 (permalink)
XLr8
^ do you mean ::
PictureBox p1= panel1[i] ????
Old 08-06-2010, 04:08 AM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
It's simple.
Cast the Control returned to PictureBox.
dheeraj_kumar is offline   Reply With Quote
Old 08-06-2010, 09:45 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by arpanmukherjee1 View Post
hello,
i have a panel.
            label.Width = 100;
            label.Height = 30;
            box.Name = "image";
            box.Image = image;
how to do this??
u r using a subroutine.....& adding label & picturebox in panel.....
but i didnt get ur question...u want to get the picturebox then u can use
panel.findcontrol() method......
Old 09-06-2010, 12:16 AM   #6 (permalink)
XLr8
it's done. it returned PictureBox type .
thanks 2 u all 4 ur efforts...............
SamSung 226BW Review rajesh201985 QnA (read only) 7 19-10-2007 02:58 PM
How To HIDE applets from the Control Panel. anandk Tutorials 7 11-02-2007 05:41 PM
How to use flashget in opera 8 Gaurav Software Q&A 6 22-10-2005 11:19 PM
Use "Windows" your own way ! rajkumar_personal Software Q&A 6 26-02-2005 11:40 PM
Lost Control over Control Panel! lamrinnirmal QnA (read only) 5 16-11-2004 08:35 PM
